Question about Optoma Projector Hd600x-lv
I have plugged in a Optoma HD600x-lv, and nothing. No motor or lamp. Dont have remote, so pressing power button on top. Nothing. Any ideas?
Power checked at plug, good, but no life in the projector at all. Any ideas?
Hi guys,
Just to share my experience. I replaced the lamp after using a HD600x after 6 years, because the lamp did not switched on, and the red LED "lamp" was on. After replacing the lamp, nothing happened! same red light lamp on, and the same if I remove totally the lamp (and closing the lamp compartment). Then I was almost decided to resend the new lamp to be refunded, but meantime I opened the projector, remove plastic and metal layers, and I saw a huge amont of dust. I cleaned all I can with vacuum cleaner, the electronic card etc... and all worked fine now!
even with the former lamp. So the problem was that a huge cleaning was necessary.
Hope it help
Nicolas
Posted on Aug 31, 2017
  • 45 Answers
I'm assuming the warranty is expired. But if the projector doesn't respond to direct power, you'll have to have the circuit board and power supply checked out.
Only other option might be to ensure you have the power cord plugged in thoroughly or swap it out.
Posted on Nov 19, 2014
marsrover
  • 682 Answers
SOURCE: projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
Posted on Sep 22, 2008
SOURCE: optoma ep739 won't power up
The lamp cover has a disconnect that won't allow power while the cover is off. Sometimes the piece of metal gets bent out of place.
Try removing the cover for the lamp, and bending the little piece of metal forward.
It worked for me!!!!
Posted on Nov 27, 2008
  • 7 Answers
SOURCE: power for optoma ep 716
TAKE TO THE AUTHORIZED SERVICE CENTER OF OPTOMA
WANT ADDRESS goTHROUGH WWW.OPTOMA.COM
Posted on Jan 30, 2009
projdoc
  • 2237 Answers
SOURCE: My Optoma EP716 projector will not power up; no
power supply has a fuse on it. if the fuse is good, the power supply needs replacing.
Posted on Jul 22, 2009
  • 5 Answers
SOURCE: Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Posted on Oct 03, 2009
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
May 23, 2014 | Optoma MovieTime DV10 DLP Projector
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
My projector will not power on. I've replaced the cables, the power source, and the bulb but still nothing. The red standby led on the control unit turns blue when power button is pressed but goes right...
The ballast unit has most likely failed. Replace the ballast unit, unless the lamp exploded and in which case, there may be glass fragments stopping a fan from turning.
Feb 03, 2011 | Optoma HD81 DLP Projector
Optima EP719 won't power on - when power button
check that the lamp is on securly and that the cover is on securly too.
Feb 02, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma h 27 will not power on at all. New lamp still not working.
Never heard of a heat reset. If the unit is completely dead. investigate lamp, and or lamp door interlock switch.
May 18, 2009 | Canon LV-S3 Multimedia Projector
Projector has no power
Aug 27, 2008 | Optoma EzPro 739 Multimedia Projector
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Open Questions:
Optoma Projector Hd600x-lv Logo
146 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
