Ups not running on battery - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 26,176 Answers
Exhausted battry?
Posted on Nov 13, 2014
2010 Honda Odessey Handicap Van won't start after sitting for a couple of days. Have a new battery bewst from Sears. Mileage iiiis @ 7K miles. and we don't use the van to often.
Not clear what is happening but you say it does not run a lot of miles. I do know even with a new battery the van must run every once in a while to keep the battery charged up. Batteries run down just sitting and has to run at least a number of miles to charge up. I suggest you purchase a little battery charger that you can leave hooked up to the battery all the time and when you want to use the van just pull the plug out of your extension cord. Then plug it back in when you are back home. That way you know the battery is charged fresh all the time. You might want to have the battery checked for power just to make sure the battery is operating properly. Any place that sells batteries should do this for free.
Aug 22, 2016 | 2010 Honda Odyssey
2010 Honda Odessey Handicap Van won't start after sitting for a couple of days. Have a new battery best from Sears. Mileage is @7K miles. and we don't use the van to often.
My 1989 cadillac deville was running yesterday got in it this mourning it starts right up after 10min of running it dies i jumped it off it started back up then died again now when jumping justclicks
Sounds like you have a faulty alternator, sir. Your car seems to be running off battery power. Once the battery power is exhausted, the engine dies. It will start and run again if you charge the battery, but only for a few minutes until the battery dies again.
Nov 02, 2015 | Cadillac Cars & Trucks
Wont start or stay running unless battery charger is on it
some four wheelers require a battery to run correctly. sounds like you need a new one.
Mar 26, 2014 | ATVs
300 watt manual
Your not asking the right question. The answer is dependent upon how long you want the backup to work. Does a battery fit in the unit or is it alone? If you were to connect a car battery to the unit it would run for many hours, say a motorcycle battery would run maybe an hour. It is all about the time you want for run time.
Mar 25, 2014 | CyberPower Computers & Internet
I have a 1994 f-150 pick up got a new battery & when i put the heat on it discharges & now truck won't.
You mean with the engine running? If the engine is running, the heater fan should be getting power from the alternator, not the battery. Does your battery light go off after engine is running? Or does the voltage gauge show normal charging when running?
If you can start the truck, have your charging system checked out. If it won't start now, have the battery charged up and try again. Then have the charging system checked. If it is good, your heater fan may have a short and drawing too much current, But a heater fan will run the battery down pretty quick, if the engine is not running.
Jan 06, 2013 | Cars & Trucks
Doge neon keeps diying
It can be your alternator. Did you know that when the car is running, the alternator is meant to be the sole source of electricity to run everything? The battery is only there to initially power up the car and crank it over. Once started, the alternator takes over supplying power to run the car.and charge up the battery .But if the alternator is not working, the battery supplies the power till it runs out of sufficient voltage, and the car will die.
Does your alternator/battery light go off as it should, after engine is running? If not, you have a charging malfunction and need to test the alternator If the alternator is good and is charging the battery back up every time it runs, then you have an ignition problem, not a battery or alternator problem.
Good luck, and hope you find the problem.
Jun 02, 2012 | 1995 Dodge Neon
Hi my makita 18v impact driver seems to be getting alot weaker throughout the years, still works but no enough torqe
Lithium batteries have a limited lifespan, typically 3 or 4 years, and their capacity between charges decreases over the years.
To extend the lifetime of a battery it should be run completely flat after every few charges rather than topping it up. New batteries need to be charged several times and run flat under normal use before they gain their full capacity.
Apr 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Battery is drained
try an old fashioned battery boost from another car or truck. leave the other car running while boosting your. run booster cable from the booster car to your truck make sure to run them the same way on each battery. positive on booster to positive side battery on the truck. run the negative from booster car to negative on your truck. allow the car to run for about 10minutes before you attempt to start your truck. this allows your battery to build up enough charge for the start up of your truck. after your truck starts take the cables off right away. let your truck run for at least 15minutes to allow time for your battery to build up before you attempt to drive it.that way if it should die,you'll have enough charge on your battery for a restart. thank you for choosing fixya.com hope this helps.
Jan 10, 2011 | 2004 Ford F250
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Feb 07, 2009 | Pride New Mobility Victory XL 4 Wheel...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
