Question about Dryers
I have replaced the Control Board, but still have the Lights flashing and Beeping ? Is there another Part to check ??
    Master:
  • 487 Answers
What brand?
Posted on Nov 13, 2014
2 Suggested Answers
emissionwiz
  • 76118 Answers
SOURCE: Dryer is beeping 9 times error code. No flashing
Was the motor tested and it passed?
Posted on May 13, 2011
I have replaced the Control Board Frigidaire Dryer ModelFEQ1442 ESO, but still have lights flashing & beeping
Probably you didn't install it correctly. Bad luck, so you should contact an athorize repair service
Nov 13, 2014 | Dryers
Stitch selection control panel lights flash and beeping
is the bobbin lever back in it's original position? it could be a problem with the computer, here is a link for a free manual, just in case you don't have one
http://www.singerco.com/uploads/download/466_7462_efs.pdf
Apr 17, 2014 | Singer 7462 Sewing Machine
Dle2701v beeping flashing lights
It may be solve problem or maybe your dryer have some problem with motor also
The best method is to do your home work and you must do total trouble shooting procedure and replace defective parts if necessary .
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 07, 2013 | LG Dryers
Control panel beeping and lights flashing.
This is a fault with one of the fan motors, but to fix this correctly you will need to locate with fan has the problem and replace bot h the electronic control and that fan motor. Disconnect the power to a fan motor, when the panel stops flashing thats the motor that needs to be replaced. I have found the most common is the fan motor in the freezer as it ramps up and down frequently. This fan is variable speed and causes the board to fail. Failure to replace both at the same time will cause a repetitive problem.
Good Luck
Nov 21, 2013 | KitchenAid KSSC48QMS Side by Side...
GE gld5708vbb flashing lights locked controls
It is possible that since the neutral was bad it could have made a surge on the power and caused the processor controller to fail. It is also important that this must be confirmed to be corrected by checking with a larger load like a heater being switched on and not causing any voltage drop. If so the line is clear. Also make sure that the ground - Earth- is also intact.
The program has reset because of an error and it must be confirmed to be within or outside the washer. So remove plug and test this terminal with a large load test to confirm that the outlet is OK.
If so check the panel connections or is best to refer back to the dealer as the replaced panel will have a warranty.
Please take second opinion before the board is removed.
Jun 28, 2012 | GE 24 In. Black Built-In Dishwasher -...
I have a frigidaire dryer (front loader) and the it keeps flashing 'error' and continuously beeping - The dryness panel has all 4 lights blinking. It's a stackable, so I can't get in the back to try and...
Try and turn off the main circuit breaker to the unit for a couple of minutes.if this does not reset the machine you may need to replace the control board make sure to check and make sure none of the buttons are stuck.
Sep 08, 2010 | Frigidaire Dryers
Washer flashing fault codes
truthfully, i think you have a malfunctioning board.if all parameters are correct and unit is washing while beeping is taking place. represents board.
May 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
