Question about Saturn 2008 VUE 4-Cyl XE
Change thermostat Need to know what all I need to take off
  • Saturn Master
  • 3,904 Answers
I am not familiar with your engine compartment but to get to the actual thermostat should not take more than a screwdriver and a socket set.
Posted on Nov 14, 2014
How to change thermostat on 1990 Toyota Taraga
Teresa, change thermostat on 1990 Toyota Taraga. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thermostat Tarago Previa Estima TCR
http://toyotatarago.net/1990-1999/online_workshop/pdf/GENERAL_COOLING_SYSTEM_SERVICING.pdf
Replacing your van thermostat
Radiator flush Motor Drain plug Thermostat TCR Tarago Previa Estima
Aug 20, 2016 | Toyota Cars & Trucks
What size wrench do I need to change the thermostat on a 2002 diamante
Were is the thermostat on a 2002 mitsubishi diamante 3.5 v6 ...
www.fixya.com/.../t15150678-thermostat_2002_mitsubishi_diamante_3...
Nov 26, 2012 - SOURCE: asistance to change the thermostat in a 2002 mitsubishi ....size wrench do I need to change the thermostat on a 2002 diamante.
change thermostat change thermostat - Fixya
www.fixya.com/cars/t19454162-change_thermostat
Aug 16, 2013 - change thermostat - Mitsubishi 2002 Diamante question. ... What size wrench do I need to change the thermostat on a 2002 diamante. May 29 ...
Unanswered Mitsubishi Diamante Car and Truck -Q&A
www.dqrkc.com/cars/mitsubishi/diamante/problems
Mitsubishi Diamante - Unanswered Questions, Problems & Issues. Ad ... What size wrench do I need to change the thermostat on a 2002 diamante.
May 29, 2015 | 2002 Mitsubishi Diamante
How do I change the battery on Honeywell Thermostat T8001C?
According to the manual for the model series (see link), only the T8002 Model has batteries. They are accessed from the right side of the thermostat. See page 14.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1431.pdf
Jan 10, 2015 | Honeywell T8001C1019 Programmable...
Need to know how to change a 2004 Dodge durango thermostat
Thermostats for Dodge cars available at buyautoparts which offers you free shipping and discount prices. You can find the parts here http://www.buyautoparts.com/thermostat.htm
This is a video which helps you to change thermostat http://bit.ly/dodgethermo
Apr 10, 2011 | 2004 Dodge Durango
I have a 1995 ford escort lx 1.9 and need to know where the thermostadt is located and how difficult to change
It's fairly simple to change. Remove the water hose from the thermostat, remove the 2 bolts and lift away (may need a flat head screwdriver to pry away from thermostat housing). Below is the diagram for your thermostat. Best of luck.
Greg
Oct 25, 2009 | 1995 Ford Escort
I have a 1995 chevy lumina and need to know how to change the thermostat, can you help? What do I have too take off of the car to get to the water pump so that I can change out my thermostat?
You don't remove the water pump to change the thermostat, that's not where it is. It's at the engine end of the upper radiator hose that connects the radiator to the engine. How do you know that you need one? Are you overheating? In a car of that age you could easily have a plugged up radiator, you would want a reverse flush; watch the newspaper ads for a discounted price on that service. If the coolant is dirty, not bright green it will be deteriorated and will overheat. For extra they'll also change the hoses and thermostat. It can add up so shop it around.
Jun 09, 2009 | 1997 Chevrolet Lumina
Changing a thermostat in a 1997 Oldsmobile Cutless
The thermostat is on the intake by the exhaust cross over. The crossover will have to be removed to get the thermostat housing out. If the intake gaskets are leaking fix them and change the thermostat while the intake is off. The only reason I say this is because the intake gaskets are a common problem.
Dec 27, 2008 | 1995 Buick LeSabre
Need to change my thermostat on my 1999 Jeep Cherokee Sport 4WD
I do not know a link to a diagram, but I can certainly tell you how to find the thermostat! Looking at the front of the engine, there is a large water hose at the top of the motor that goes to the left, and attaches to the radiator. Not the radiator end, but the other end attaches to the thermostat cover. It has 2 bolts to take out and the little thing between that, and the motor about 2" around that kind of looks like a spinning top, is the thermostat. It is easy to change. Make sure you get ALL the old gasket off and that both bolts go through the new one, and you should be in business!
Dec 21, 2008 | 1999 Jeep Cherokee 4WD
Whirlpoool dryer not heating replaced the thermostat
Dont know the model number you have, but most of your items are located in the back of the unit. You need to make sure you replaced the thermostat, and not just the thermal fuse. The thermal fuse sits on top of the element shield, the thermostat is lower, down where the wires go into the element. You may have changed the thermal fuse, but the thermostat may be out. You will need to check (with an ohm meter) all the componants to find the trouble. If that thermal cut-off has went bad again, change the thermostat with it. Be sure you have very good ventilation all the way through, bad vents will cause problems like this all the time. Let me know if you need parts info. Let me know a model number as well.
Nov 16, 2008 | Dryers
Saturn 2008 VUE 4-Cyl XE Logo
44 people viewed this question
Top Saturn Heating & Cooling Experts
Tom Chichester
Hank O
Level 1 Expert
David Ellis Rhea
Are you a Saturn Heating and Cooling Expert? Answer questions, earn points and help others
