Question about Lands Phones
How do I use my instrument for the first time?
  • Lands Phones Master
  • 5,631 Answers
You should go to the place where you bought your instrument, or if you bought it by mail to any site where they sell it, and ask for help. Actually, you are not specifying about WHAT instrument you are talking
Posted on Nov 13, 2014
All my gauges just quit working. car still runs fine. they done this 2 or 3 times but would always start again. this time have not come back on. turn signals and dash lights work just no gauges.
At the moment, your instrument cluster maybe faulty? Due the basic tests, try to be sure. Check for applicable trouble codes relating to instrument cluster--pcm--communication codes. Some of the national brand auto stores in this country may check codes for free, if there are any.
Check voltage and ground circuits for the instrument cluster. The sending units for gages are wired to pcm then the pcm sends serial data to instrument cluster telling instrument cluster what to do with gages. If you want to check gage sending units, that's ok.
If you have a scanner that can communicate with instrument cluster, you can get instrument cluster to do a self-test. The self-test, the instrument cluster will turn warning lamps on and off, sweep gages w/o outside data input. The instrument is considered good, if it passes that test, if not, the instrument cluster is considered faulty.
Apr 28, 2016 | 2002 Pontiac Bonneville
Instrument cluster is not working properly
Check for lose terminal pins at the instrument cluster connector . sounds like lose connection or lose ground wire !
Jun 18, 2015 | Cars & Trucks
I have an Omega/Lambda/Lexicon and the vocals seemed to be delayed with the timing established by the instruments. Any ideas of what to do?
Without the configuration you are using we have little to go on. How is the system wired? Are you saying when you run instruments AND mics into this then record they do not play back together? If the instruments are MIDI types and you play back along with the vocals I would expect the MIDI instruments to be delayed a little as it takes time to transmit the note info at 31.25Kb... It takes about 1/3000 second for EACH MIDI character and note messages take three of those for a total of about 1 ms. One millisecond IS noticeable by the ear... and if you have several instruments it may take several milliseconds to service all the instruments. If you are recording ANALOG instruments the delay should be imperceptible.
Apr 26, 2011 | Lexicon Lambda 4x2x2 USB Audio Interface
Oil pressure gauge works some time 1995 S420
possibly faulty instrument cluster, also can faulty oil sender, instrument cluster is most common problem for this case, it's some time oil presser sender also create the same problem, need to be check first both of them, first check the oil sender if it's OK faulty instrument cluster, get repair instrument cluster, is this information helped you?
Oct 26, 2010 | 1995 Mercedes-Benz S-Class
Speedometer dont work
Often in 03-06 Chevy Tahoes the instrument cluster will start to go out one gauge at a time. This is due to the stepper motors failing, to find out how to fix your tahoe instrument cluster check out this page Tahoe instrument cluster fix
Jun 29, 2010 | 2003 Chevrolet Tahoe
For 1998 Dodge Grand Caravan,instrument clusters with light when ignition turn on, but there's no crank and no start. Battery just changed five months ago
I have a similar problem. Do you also notice the gauges on the instrument panel going out from time to time? (Have to slap the dashboard.) I have been told the start problem is related to a problem with the instrument panel (a control unit contained therein). I have found at times turning the key to the ON position for a few seconds (odometer lights stabilize) before moving to the START position sometimes helps.
Unfortunately, replacing the instrument cluster/control unit can cost up to $600-700. I am not a mechanic, but have inquired about this for my own Caravan. Good luck.
May 27, 2010 | 1998 Dodge Grand Caravan
How do i remove dashboard clocks
Do not leave the instrument cluster face down for any length of time. Lower and extend the steering column to its maximum rearward position. Disconnect the battery ground cable. Remove the air vent. Release the tangs. Remove the air vent. Remove the air vent. Release the tangs. Remove the air vent. Remove the center air vents. Release the tangs. Remove the center air vents. Detach the switch assembly. Remove the switch assembly. Disconnect the electrical connector. Remove the instrument panel veneer trim retaining screw. Remove the instrument panel veneer trim retaining screws. Remove the instrument panel veneer trim retaining screws. Detach the instrument panel veneer trim. Remove the instrument panel veneer trim. Detach the instrument cluster. Remove the instrument cluster. Disconnect the electrical connectors. To install, reverse the removal procedure.
Jul 28, 2009 | 2002 Jaguar X-Type
Instrument cluster removal 1965 mustang
  1. Disconnect the battery cable.
  2. Disconnect the speedometer cable from the speedometer head.
  3. Remove the six screws retaining the instrument cluster assembly to the instrument panel and tilt the cluster forward.
  4. Disconnect the wiring and the bulb sockets and remove the cluster assembly. NOTE: All individual instruments may be removed and serviced at this time. To install:
  5. Position the cluster and connect the wiring and bulb sockets.
  6. Install the instrument cluster assembly to the instrument panel with the six retaining screws.
  7. Connect the speedometer cable and the battery cable.
  8. Check the operation of all gauges, lights, and signals.
Jun 25, 2009 | 1965 Ford Mustang
2003 MB E320 Sedan - how do you change the time on the clock?
kavtrom to reset the clock you use the instrument cluster by navigating the steering wheel multi function keys untill cluster states settings-after you have set the time while the instrument cluster multi function screen is still at the clock settings you have to press the the reset button/dimmer knob on left side of instrument cluster and the clock will go backwards until 9-10 oclock and then will forward itself to the correct time
Mar 28, 2009 | 2003 Mercedes-Benz E-Class
NO START
This problem can be three things. The ignition switch is a good place to start but its under a recall and you should not spend any money on this repair. The passlock system next to ignition switch should probably be changed at the same time and is also under a recall. The instrument cluster is the most probable in your case. The reason i say that is because the key is the headlights not turning on you may also have some lights on the instrument cluster flickering on and off at weird times.The speedometer or other gauges are probably not working all the time. if you are handy you can remove the cluster and send it out for repair. The tech who repairs this might even tell you that the instrument cluster has nothing to do with non start issue but it does. the passlock anti theft reads the ignition key when you insert it into ignition cylinder. Once you turn the key the ignition sends a signal through the instrument cluster to the pcm. the pcm will allow the car to start if the correct signal is recieved. If the pcm recieves no signal it allows the car to start for a second and then kills the car.
Oct 01, 2008 | 1997 Oldsmobile Achieva
Lands Phones Logo
22 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
