Question about Balboa Instruments BALBOA BOARD 100 MORGAN SERIAL STD W PHONE PLUG ()
Where may I obtain a schematic diagram for Balboa Spa control board H716R1A
Need Schematic diagram for Balboa H716R1A Spa Control board
  • 5,631 Answers
Probably the only one who can provide you is the distribuitor of the board.
Posted on Nov 13, 2014
4 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
SOURCE: hi have problem with canadian spa
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Posted on Sep 09, 2011
SOURCE: I need to replace my
The best suggestion in this case would be to replace the spa pack and upgrade. this is a really old system. You can replace the entire system for around $500.00 and have the latest working technology along with a new topside panel, overlays, heater, system, etc. The Balboa Value Pack Retrofit kit comes with everything you need along with cables. Since you have Weslo with an oval panel, the best suggestion would be the Balboa 54219-Z Value Pack Retrofit Kit. you can get it online by clicking on the link I have provided.
Hope that helps.
Balboa Direct
Posted on Sep 12, 2011
Pure spa control panel film or diagram where is fuse
open up control panel schematic inside cover
Jan 17, 2016 | Intex Pool & Spa
How to disable bubbles that come on now when I turn on heater. The bubble switch will not do it. I want to cut a wire in the main unit.
open up inside control panel there is a schematic unplug bubble switch maybe bad control board or stuck relay
Oct 22, 2015 | Pool & Spa
What runs on the .3amp fuse?
look on inside cover of control unit it has a schematic
Jul 04, 2014 | Balboa Instruments Pool & Spa
Balboa vs501z
There should be a schematic on the inside of the spa pack load box cover. It is either a 2 prong location or 4 prong. Depending if the temp sensor is in the same plug as the hi limit sensor. It usually is along the outer edge of the circuit board.
Dec 23, 2013 | Pool & Spa
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
I just bought a used balboa hot tub and have no expertise. Does the pump kick in automatically even when you turn it off it will turn back on instantly? Is that normal? If it is not normal what could be...
This does not sound normal, but in order to better diagnose this I need to know exactly what model of controls your spa has. This is easily found on a label on top of the control box in the spa cabinet. If the label is missing, then remove the control box cover and look at the inside of the cover for the schematic, should be a model number on it.
Aug 25, 2010 | Balboa Instruments Duplex Digital Panel 2...
Does anyone have the schematic for LCD control
Tom,
I don’t believe you will find a schematic for the control board. I have a FAV6800AW all I have be able to find is the wiring schematic found in the FAV6800AW/FAV9800AW Service Manual.
Is your machine out of the 5yr warranty period for the Control Board? I got Maytag to send me one.
Saw this on e-bay
NEW - Maytag Washer LCD Control # 25001189
Good luck … Rich
Oct 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Balboa Instruments BALBOA BOARD 100 MORGAN SERIAL STD W PHONE PLUG  () Logo
232 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
