Question about Brother PPF-5750E 33.6K bps Super G3 Fax Modem B/W Laser Technology Fax Machine
Changed toner cartridge and now keeps stating error...change toner cartirdge
  • Brother Master
  • 3,904 Answers
In the menu on the printer have it run a thorough cleaning on the print heads. Should be in the set up menu.
Posted on Nov 14, 2014
3 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: Change toner and it comes up with Toner Life End
Im think you leave the cover open and hold down clear
Posted on Jan 21, 2009
dburns60
  • 410 Answers
SOURCE: toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Posted on Jul 03, 2009
Replacement toner cartridge not accepted
I Suggest You To Watch just replaced the toner cartridge and the LCD continues to Brother To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jun 11, 2012 | Brother Toner Cartridge Tn350 for MFC7420...
I changed my Canon PIXMA MP780 3e cartridge, and
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 10, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have 3 bottles of toner. How can I refill mt HP
There is no point in trying to home refill toner cartirdges unless you have an effective way of managing the waste toner. Almost all toner cartridges, including yours, have a waste toner hopper that holds the toner which was cleaned from the imaging drum that did not go on the paper. If you are unable to empty this is will eventually overflow into your printer, make a huge mess and possibly damage the machine. Also, the components in the cartridge are only intended for one time use, they will need to be replaced. If not the special coatings on them will wear off and the cartirdge will just fail to print. I would recommend high quality refills from a reputable seller who replaces parts, not just reuse, this is important to ask.
Jan 14, 2010 | HP LaserJet 1100 Printer
We have a Sharp 1641CS copier will not feed or copy
Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
May 29, 2009 | Sharp AL-1641CS Copier
Flashing amber warning light
The problem is that the MICR Toner Wire was placed into the wrong jumper position on the TROY Font Card. By moving it to the other jumper, this should clear your 'Invalid Toner Sense State' Error. If you need further assistance, please feel free to contact me at 800-633-2266 x 218 or vial email to bmcmillen@troygroup.com.
Regards,
Brian
Mar 20, 2009 | Troy MICR 2200T Secure Laser Printer
Samsung CLP 300 won't print
a few seconds after turned on?
after a half hour ?
in the first case it indicates a problem most likely with the fuser.
in the second case it might be on a timer.
Aug 05, 2008 | Samsung CLP 300 Laser Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
Brother PPF-5750E 33.6K bps Super G3 Fax Modem B/W Laser Technology Fax Machine Logo
164 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
