Polaroid tv freezes onto a black screen when change channel. Have to end up switching tv off at mains.
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Try a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 14, 2014
SOURCE: Polaroid LCD TV 37" Black screen
I had the same problem. But found the fix on this website!!
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Sep 05, 2008
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
SOURCE: 42' polaroid tv wont show screen still
it is a manufacturing defect. Mine had it. My advice is to never buy polaroid tvs. but anyway, here is a link on how to fix the problem...
http://www.fixya.com/support/p443928-polaroid_flm_3732_television/tips
Posted on Dec 29, 2008
RNS-Systems
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Posted on Oct 16, 2009
  • 19 Answers
SOURCE: Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
To add to this solution above - I had the capacitor replacement and there was still an issue. Turns out the solder connection to the lamps themselves was very very poor causing an electrical arc (the scratching noises people are hearing) - then the inverter shuts the lamps down as it should. Fix lights!
Posted on Dec 10, 2009
Hi my polaroid LCD flat screen TV is behaving strange. I've had it almost a year and problems have started the last few days. Basically when I change the channel the screen will go black and freeze. The...
would need the model number but it sounds like a software fault, this can be the control switch chip, does it do this on source to, some times can be fixed with the tv board being clean'd and the dust removed from the board. if there is a lot of dust build up it can cause problems with the micro chips connections you get a statick build up from the dust and make the board do strange thigs
May 09, 2014 | Televison & Video
How do I fix?
Sounds to be a firmware corruption. Update its firmware with latest version than it have now. Gopakumar Gopalan Google
May 09, 2014 | Polaroid Televison & Video
Why is my polaroid 22 inch TV DVD combi not working?
Hello, it sounds like the main board has gone bad (the tuner is mounted on the main board). The cost of the board replacement may be close to the cost of a new set. You may want to explore that option....tks....Terry
May 08, 2014 | Polaroid Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
My TV freezes instantly when it turns on.
Take the tv aparts cleans all parts and disconnect an reconnect everythings.It will work,or u might also need to replace the Video ic inverter board.
Aug 23, 2009 | Televison & Video
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Black square on screen
I hit the freeze button and it came offf
Sep 22, 2008 | Polaroid TLA-01911C TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
