Question about Acer Iconia One 7 B1-730HD-11S6 7-Inch HD Tablet Titanic Black
My charger will not charge up ,every time I plug in the leads nothing happens I have tried blowing in it , changing the power leads, everything! In at my wits end any idea s please? I cannot afford to
Every time I plug in the charger it will not charge my tablet up , I have tried ,,,cleaning the pin that gos into the tablet, changing the charger, everything but buying yet ' another' charger. Which looks like the only alternative to my fixing this problem!!!
    Habit-Forming:
  • 32 Answers
If it is a micro USB plug in... take a look at the tablet where it plugs in. See if the little flat piece is bent at all. This is a common problem with phones etc. If it is bent to one side. Take a thin PLASTIC flat tool, and try to gently pry it back to the center. It may take a bit of prying to get it to be in the middle and stay there. If that does not fix the issue. Either the battery is gone, or a broken connection on charger on the tablet end.
I have saved people hundreds if not thousands with this issue.
Posted on Mar 10, 2016
    Master:
  • Acer Master
  • 993 Answers
U need a new charger,or clean chrging connector
Posted on Jan 09, 2015
    Sergeant:
  • 247 Answers
Try charging it with a USB cable in your PC. If that doesn't work, it is your battery or connector.
Posted on Nov 15, 2014
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Tablet was charging and I was playing candy crush then it turned off. Hasn't turned back on since. Tried charging it but No indication that it is charging. Tried The power button and hold volume button and...
Try a different charger. The tiny wires in charging cables are delicate and break easily. You may have had the tablet connected to the charger and nothing was happening and you ran the battery till it was dead.
Feb 20, 2015 | Tablets & eReaders
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
I have an ematic tablet model:EGQ307 when i plug in the charger nothing happens when i try turning it on still nothing do you have any idea how to fix this?
Try to fine out what is defect the charger, the cable, or the tablet, by testing other cable, charger and tablet. not all 3 the same time, but one at the time.
Jul 13, 2014 | Tablets & eReaders
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
How to charge a cruz tablet r102
That happened to me about 2 hours ago. What i did was take the back piece of (be very carefull) and blow into the back. Then Plug the charger in and turn on the power put or oush the power button. It takes a little time because you have to keep trying. If the back is hot take the back cover off and blow on it also. If that doesnt work send me another message or a reply!
May 02, 2013 | Velocity Micro Cruz SE R102 Android Reader...
Blackberry tablet wont power on
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
May 04, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Acer Iconia One 7 B1-730HD-11S6 7-Inch HD Tablet Titanic Black Logo
267 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
