Question about Kenmore Refrigerators
How do I change light bulb in freezer - Kenmore Refrigerators
  • Kenmore Master
  • 744 Answers
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
I would like to help you but you did not provide a refrigerator model number, which is on the fresh food section liner wall. replacement is different depending on your model number.
When you do change the light bulb, it is a special bulb, you may be able to find it in your local supper market, or have to go to your local Home Depot.
Posted on Nov 14, 2014
How do you change the bottom freezer light bulb
Hello Joe;
This is Peter again. I just responded to your question. Please send me the model number.
Bottom freezers should be out-lawed. They are the highest maintenance and most difficult to service.
Nov 13, 2014 | Kenmore Refrigerators
How change freezer light bulb on model LFC 21776
yes to both, and I believe to remove the light bulb cover you gently lift up and out to gain access to the bulb.
Sep 18, 2014 | LG LFC21776ST 21 CF French Door Refer Cab...
Light bulb is not working. how to change it and what kind of bulb is it model: FKFH21F7HW
Good Afternoon Rose, I am happy to assist you!
Before replacing the light bulb in your Frigidaire freezer please confirm that the temperature control is set in the OFF position and unplug your appliance to avoid electrical shock. Typically, you may remove the light bulb by turning it counter-clockwise. The old bulb can be replaced by an equivalent watt bulb (part number is 216988100) available either from part distributors or hardware stores. I hope this information helps to some degree!
Feb 25, 2014 | Frigidaire FKFH21F7HW Freezer
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 | Freezers
Freezer light won't come back on .
Is that a florescent bulb in the freezer? Or is there some kind of light bulb in the freezer? If so, change the bulb. I'm not being funny. You give no information on what make, brand and year of the freezer to give you any help.
Apr 07, 2013 | Freezers
How to replace the light bulb in the Maytag french door bottom freezer
Hopefully you have figured this out. Its fairly simple to do. If your freezer if full you will need to empty enough that you can place your hand in and on the Plastic Light cover. Its in the center at the top of the freezer. This cover is removed by simply applying a little pressure to the right and left corner and pulling toward you and down. The light cover with very little pressure should mover and pull down. Once it begins to lower in the back just keep a hold of it and mover your hand toward the rear of the freezer and the front tabs will slide out.
After changing the light bulb, simply put the front two tabs of the front of the cover in first and snap back into place by pushing up. Takes about 3 minutes to change the light bulb. Good Luck!
Dec 24, 2012 | Maytag MFD2560HES Bottom Freezer French...
How to change a bulb in the Kenmore refrigerator
Most likely, you never notice the light bulb in your freezer or refrigerator until it is not working. Then it is time to replace the bulb. This is especially important with freezers, which are often in areas with poorer lighting, like basements or garages. Fortunately, the task is a simple one.
Instructions
1 Unplug the freezer to prevent an accidental shock when you remove the light bulb.
  • 2 Open the door of the freezer, look at the top inside edge of the freezer, below the door seal and back about 1 to 2 inches from the edge. You will see a small plastic or metal panel that protects the bulb from damage and shields your eyes from the direct light of the bulb when the door is opened. Reach behind the guard and remove the bulb by twisting it to the left.
  • 3 Put your new bulb in by inserting it into the socket and twisting it to the right to screw it in. Be sure you use a freezer bulb--it is built a little tougher and is the correct wattage. You can find them at appliance or hardware stores. Plug the freezer back in to test operation of the bulb.
  • Have a nice day! : ))
    Jan 30, 2011 | Kenmore Refrigerators
    How to change the light in the refrig. compartment?
    Some models are different...I hope this helps.
    Replacing Light Bulbs
    To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
    To avoid personal injury or property damage, observe the following:
    • Allow light bulb to cool.
    • Wear gloves when replacing light bulb.
    Fresh Food Section
    (style of light shield varies)
    1. Slide clear light shield toward back of compartment to release from light assembly.
    2. Remove light bulbs.
    3. Replace with appliance bulbs no greater than 40 watts.
    4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
    Freezer (style of light shield varies)
    1. Reach behind the light cover.
    2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
    3. Remove the cover.
    4. Remove light bulb
    5. Replace bulb with appliance bulb no greater than 40 watts.
    6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
    Ric
    Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
    BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
    YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
    Apr 08, 2008 | Refrigerators
    Refrigerators Logo
    85 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    ka4iup
    ka4iup
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
