Question about Whirlpool Dishwashers
I have error code F8 & E1 flashing on my display. Just before these appeared, the machine was making grinding noises.
Other Part Numbers on door, are ADG 8410FD.
Master_Tech
  • 770 Answers
SOURCE: LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Posted on Aug 20, 2008
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Posted on Mar 30, 2009
Macmarkus
  • 2605 Answers
SOURCE: I currently have a whirlpool with a flashing green
I can't locate your model number, it may only be a partial number and/or missing a couple of digits or letters. Fortunately with most "Whirlpool" built dishwashers...
This is actually a built in "fault code" of your dishwasher. It could mean you have a faulty control, but not very likely. Here's a couple of things it commonly means.
1) the heater has failed/opened, so the control sensed too long of a heat cycle.
2) a wire from the element has come off, (it happens just from normal use and vibration at times) so the control senses the same fault as a "open" / defective element.
3) your wash motor&pump assembly has become seized or jammed to the point it cannot circulate the water to heat sufficiently, or heat in the acceptable time table.
Here's what you can do to check.
on the control you'll need to activate 2 buttons in sequence back and forth. The 2 buttons will be "heated dry" and "air dry". push those 2 buttons in this sequence, heated dry-air dry, heated dry-air dry.
This should activate a short "test" of the component's, i.e. water valve, detergent dispenser, wash motor, and finally drain. Try to make a note if the wash motor runs, or just "hums"/ "buzzes".
This test should also reset the control to eliminate the illuminated clean light. However, the light will continue to return until the cause is found and remedied...
...now to find the cause, **disconnect the power, shut off the breaker**
You can visually inspect the element in the tub. Does it have any "burn marks" or any holes ? No ? OK, undo the 2 screws at the bottom of the unit, commonly refered to as a "toe panel" or "kick plate", it is the access panel for servicing the unit. The panel should be easy to remove once the screws are out. (you may actually see a service sheet or tech sheet in a plastic envelope on the back of this panel. If you use it, do all us technicians a favour and put it back, lol). with the panel now out of your way, with the aid of a flashlight, look to the very back of the dishwasher. You're looking for any wires that may be disconnected, specifically a white colour wire with a purple/violet tracer on the left side of the element and a red wire on the right side connection. (don't get too hung up if the right side isn't red, it could be brown or even orange in some cases, red is just the most common by far).
If the connections are good and the wash motor & pump work, now with the aid of a multi-meter, ohm out the element.
It is possible it is defective without any visual evidence, but the meter won't lie. If you have continuity,(the needle/numbers moves) it's good. If not,(needle/numbers doesn't move) it's bad.
...the remedy, if you can rule out a loose/disconnected wire, should be obvious at this point. Either a burnt out element needs to be replaced or a bad wash motor & pump assembly has to be replaced.
hope that helps, let me know. good luck.
macmarkus :)
Posted on Nov 05, 2009
  • 901 Answers
SOURCE: Whirlpool ADG 6556 flashing code
Refer user guide for the correct meaning!
Meanwhile Check all the dispensing compartments- salt - rinse-aid, free inlet water flow and the door close.
Posted on May 21, 2010
SOURCE: adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
Posted on May 24, 2010
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Oven won't heat flashes F2EO and 5D on
    List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
    F0-E0 Analog to Digital failure
    Disconnect panel for 30 seconds
    Should the above error re-appears, replacement of the control is required.
    F1-E1 Defective ERC Replace ERC
    F2-E0 Shorted Keypad. Replace Keypad.
    F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
    F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
    F3-E2 Oven over heat Replace Sensor
    F3-E3 Cleaning Temp over heat Replace Sensor
    F5-E0 Door Error Check Door
    F5-E1 Door Latch Check Latch
    F5-E2 Door Switch Check Switch
    Below applies only to the two digit display models for the brands above.
    F0 Defective ERC Replace ERC
    F1 Defective ERC Replace ERC
    F2 Oven over heat Replace defective Sensor
    F3 Oven Sensor Open Check/Replace Sensor
    F4 Shorted wire or Sensor locate short and correct it or replace Sensor
    F5 Defective ERC Replace ERC
    F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
    F7 Shorted or sticking button Clean button or replace ERC
    F8 Defective ERC Replace ERC
    F9 Door Latch Error Check latch and latch circuit
    Mar 20, 2016 | Ovens
    Duet. What does F8E1 code indicate needs to be done to restore operation?
    Check out the Link and the info below.
    Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
    If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
    Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
    If a "flood saver" device is being considered:
    • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
    • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
    Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
    Jan 19, 2016 | Whirlpool Washing Machines
    E1 error code on omega dishwasher
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
    Aug 28, 2015 | Dishwashers
    What mean f8 e1
    what machine make model its all very well telling us a number buts its just that without detail
    we are keen too help please post a make a model we will hel F8 E1 usually F and E errors are DOOR AND EMPTY F = interlock
    so its prob the door isnt locking properly ... and perhaps its just empty so pump... you need to check the filters and the door interlock works and clicks shut when you engage a cycle
    Mar 05, 2015 | Washing Machines
    Error code F8 E1
    My Maytag MVWX700XW1 washer does not spin, the lid lock light is flashing red and when I run the diagnostics, and check the Fault Error code I get F7 E1.
    I would alos like to find the list of Fault Error codes.
    Thank you for your help.
    John
    Jan 10, 2014 | Amana Washing Machines
    Hope this helps!
    Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
    F5E1 error
    Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
    >>Exception Note:<<
    Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
    Should the above error re-appear, replacement of the control is required.
    F2-E0 Shorted Keypad Replace Keypad
    May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
    Dishwashers Logo
    76 people viewed this question
    Top Whirlpool Dishwashers Experts
    Mike
    Owen Barnes
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
