I have a 40 inch the volum keeps goin up n down first it regular then it goes real low were u could barely hear it then it returns after a min r two to regular volum
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Sounds like leaky capacitor/s at its audio output section circuit. Contact any service technician. If the transistor used to control the mute function is defective, this kind of fault can occur. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 14, 2014
3 Suggested Answers
SOURCE: TV volume suddenly low
I had the same problem and had to fix with a work around. I take the audio directly from my cable box and pipe it in to an external 'theater in a box' system.
Do you have a universal remote code?
Posted on Feb 27, 2008
allinallelec
  • 407 Answers
SOURCE: tcl tv volume goes up and down on its own
change volume switch.
Posted on May 30, 2012
Volume keeps going down
This is a problem with the sound select board, and there is no real solution. One thing to try is to press the manual volume up or down buttons on the side of the TV and keep them depressed to see of remote volume control is restored. This over rides the volume creep issue. I solved this by shorting the UP control to ground and the creep went away, but there is no manual volume control any more, but the remote still works.
Jun 23, 2014 | Sanyo Televison & Video
Low volume on incoming calls
remove battery from phone and reinstall after 10 mins... this seems to fix alot of things also go to sound setting a make sure the volume is turned up all the way
Jul 09, 2012 | Apple iPhone 3G
After playing for a while, approx 15 min, the volume dies away leaving some sound but greatly reduced. It then gradually returns to normal volume after about 3 mins. Otherwise all other functions seem to...
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Mar 29, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
We have the Bose 6 Cd radio in our 2003 Avalanche. After half an hour, the volume shuts down. The rest of the radio is working fine and if I put the headphones in the rear radio I can hear it. What would...
This is because the amp. Fault
  1. If the amp. Is getting hot turn the radio at low volume and keep it for more than 30 min. if it goes off, the amp. Is not good but if steel running you need to ventilated the amp. Check for air ventilation.
  2. The headphones are steel working because the rear audio system is not connected to the amp. That is the way it is
Jan 11, 2010 | Car Audio & Video
Volume too low. I tried to adjust higher - barely hear the beep as volume goes up, yet not load enough.
y is it that when some one call me i cant hear them in the earpiece i only can hear them in my phone
Jul 02, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
Problem with Picture and sound after about 40 mins playing time.
the unit is over heating. Make sure you hear the fan come on. Also make sure the unit is in a spot where it gets ventilation. They get real hot and need to disapate heat or the mother board burns out.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Jan 19, 2008 | Olevia LT27HVX 27 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
