Question about Breville 2200 W Steam Iron
My Breville easyglide 2200w Iron was working fine and then stopped. I have changed the fuse but it still won't turn on
I have changed the fuse and the iron won't turn on. Brand new set of fuses were used so I know its not them.
    Master:
  • Breville Master
  • 996 Answers
Check mains wire & plug
Posted on Jan 21, 2015
4 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: My Breville Jet Select Iron
Almost all iron instructions suggest using a DE-SCALE once in a while.
Depending on your water type (hard/soft) would give you a guide as to how frequent.
Most supermarkets carry some form of descale liquid
in canada CLR is a good choice
many big box stores also carry it in the appliance areas.
you dont need much and as little as 250Ml will see you for a long time.
I prefer to descale items with a full load of water at the hottest setting
Allow for addition of at least 10% descale
let it sit for about 20 minutes then pour the water out and rinse out well to remove any debris
I often do that twice in case of stubborn deposits.
If yopu ever descal a kettle or tea maker, coffe maker then rense out extra well with cold water to make sure you remove all trace of the descale.
Posted on Mar 02, 2011
ercupa190
  • 12223 Answers
SOURCE: how do i self clean a breville iron
pleasle use the owner manual for see the self clean. download from www.fitness.manualsonline.com or www.retrevo.com and proceed accoridng.
God bless you
Posted on Jul 23, 2012
ercupa190
  • 12223 Answers
SOURCE: how do i use the self clean on my breville steam iron 2400 technique
please refer to the owner manual for use. download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
Rowenta Dz9080
Check or replace fuse in plug. If that don't do it, then change fuse inside iron. Make sure iron is not plugged to supply.
Apr 28, 2013 | Irons
Water leaking from iron can you answer me third time ive asked now
see this steps and fix it. God bless you
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2012 | Frigidaire Fcl212/H 2200W Steam Spray Iron...
Anti/calc iron water pours out from evry where
  1. Unplug the iron.
Oct 15, 2012 | Frigidaire Fcl222/H 2200W Steam Spray Iron...
Rowemta DA1560 won't turn on
1) No voltage to receptacle
2) defective cord or terminal connection
3)open thermostat
4) open heating element
4a) the heating fuse blown
5) test the outlet wal with lamp desk, if work, the iron is the problem follow the steps before mentioned. reset the c.breaker or change the blown fuse is necessary.SEE the diagram
God bless you
Sep 09, 2012 | Rowenta DA1560 Iron
My team generator iron will not steam
Have you any other suggestions? Yes. Dump it.
Jul 16, 2017 | Morphy Richards Irons
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
I need a manual for swan steam generator iron item si4030n
http://www.swan-brand.co.uk/swan-2200w-steam-generator-iron-1.html see Documentation http://www.swan-brand.co.uk/media/swan/ib/SI4030N.pdf
Jun 15, 2012 | Irons
Iron getting power light on but not heating up and dripping water
I have a Breville Iron 2200W it went into auto shut down and now i can't get it to work
Jun 30, 2011 | Breville Irons
Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Dec 23, 2007 | Irons
Breville 2200 W Steam Iron Logo
218 people viewed this question
Top Breville Irons Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
