Question about Kenmore Refrigerators
How do you change the bottom freezer light bulb
How to change the light bulb in freezer
  • Kenmore Master
  • 744 Answers
Hello Joe;
This is Peter again. I just responded to your question. Please send me the model number.
Bottom freezers should be out-lawed. They are the highest maintenance and most difficult to service.
Posted on Nov 14, 2014
How do I replace my freezer light
An owners manual I found online says:
Freezer
  1. Pinch rear tabs on light cover and pull straight down.
  2. Remove light bulb.
  3. Replace bulb with appliance bulb no greater than 40 watts.
  4. Insert front tabs of light cover into freezer liner and snap rear portion over light assembly until rear tabs engage.
The manual illustrates the bulb is behind a plastic grille right by the temperature control knob.
Aug 05, 2014 | Amana ARB1917CSR Bottom Freezer...
How to change light bulb in Kenmore refrigerator serial no. 4A31214613 ?
Open freezer and reach to the back of the plastic cover over the light. You'll feel a gap in the back center of the cover. Gently pull forward and the cover will drop down and pull to the back to fully remove it. Once you've removed the cover you can unscrew the bulb, which you can use to make sure you purchase one like it and most hardware stores, such as Ace or Home Depot. Reverse the removal instructions to install light and cover. Light should turn on once you've screwed it in.
Jul 22, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer bulb out changed nothing
this is simple... either the light has blown or the door switch is bad. Heh, stuff happens! You can substitute a regular light to check that first. if still no light its the switch most likely.
Apr 27, 2014 | Samsung RF267ABWP (25.5 cu. ft.) Bottom...
How to replace the light bulb in the Maytag french door bottom freezer
Hopefully you have figured this out. Its fairly simple to do. If your freezer if full you will need to empty enough that you can place your hand in and on the Plastic Light cover. Its in the center at the top of the freezer. This cover is removed by simply applying a little pressure to the right and left corner and pulling toward you and down. The light cover with very little pressure should mover and pull down. Once it begins to lower in the back just keep a hold of it and mover your hand toward the rear of the freezer and the front tabs will slide out.
After changing the light bulb, simply put the front two tabs of the front of the cover in first and snap back into place by pushing up. Takes about 3 minutes to change the light bulb. Good Luck!
Dec 24, 2012 | Maytag MFD2560HES Bottom Freezer French...
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
Internal light not working.I have changed the bulb,but it appears there is no power to the light socket.
hi there this roblem is usually caused by either ...(a) blown bulb....(2) fauly door switch.....
remedy....test and if necessary relace bulb...remove and if caable reair door switch or relace the switch
regards Sir Galahad
Aug 12, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
MAYTAG MBB1952HEW - Bottom-Mount
I have this exact problem...was there a solution? Frost is causing bottom freezer door not to work, when I remove the frost, the light comes on. The gasket looks fine. Any Ideas?
Aug 14, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerators Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
