Question about Imation 02395 Ml410bk Memorex Elec Portable Line-in Stereo Speaker
Where can i get the ac/dc power cord for player Ml410bk
Need power cord ac/dc mn# y12fe-050-1200u Dc.5v in/entree cc 5v 1200AMa
I misplaced the power adapter for my mxq pro help
Android TV Box Power Supply Adapter 5V 2A AC/DC For M8S/M8S PRO/MXQ/MXQ PRO
5 VOLTS DC @ 2 AMPS... 95% sure it's a 3.5mm jack!
eBay:
Android TV Box Power Supply Adapter 5V 2A AC DC For M8S M8S PRO MXQ MXQ...
Dec 17, 2017 | Power Computers & Internet
Tip
How to test an LCD TV or monitor PSU and inverter
Hi.
Before proceeding I assume you have technical training along with the multimeter. A full testing must be done with power on, and for safety reason must not be done by an untrained user.
The tip contains only general indications. The reader is supposed to have the training to apply in practice the testing method below.
If there is no power at all, then the responsible is almost always the PSU.
When there is no power, test AC in to PSU. If there is no AC in (read volts, or read ohms on power cable), that means that the power cord must be replaced.
If there is AC in, then test the PSU section near to AC input. You always find a resistor or a fuse in there . Check if it has blown.
After that you test the rest of PSU component. If there is no power at all , and problem is not power cord, it is often possible to spot at a glance a leaky or bulged capacitor.
If there is power, but the monitor stays in standby, then te PSU is forced to low voltage only by controller board. This happens when a fault had been detected.
In this case testing the PSU becomes more complicate. The technician must locate the control lines from controller board. This control lines operate at lower PSU voltage (often +5V), and turn on higher voltages on PSU board.
The inverter may use for example a +20V line from PSU. The +20V line is turned on by the controller board, closing a +5V control line to PSU. When PSU is in standby mode, the technician testing the PSU must bridge the +5V line with the PSU low +5V circuit, and test if the +20V line to the inverter gets turned on.
As explained this kind of test must not be done by the unexperienced user, as the chance to waste the unit beyond repair is high, and there are also many safety concerns.
After testing the PSU, next part to test will be the inverter board.
The inverter is tested reading DC voltage in from controller board, and AC out to back light system.
The inverter is an high voltage board, remember, safety first when testing AC circuit.
If the inverter has no DC from controller, then test PSU, if PSU is OK, and inverter has still no DC in when PSU line to inverter is on, then replace controller board.
If the inverter has DC in, and no AC out, then replace the inverter.
If the inverter has DC in and AC out when higher DC voltage to inverter is turned on, then test at component level the main controller board, and if present test LCD controller.
Regards.
on Mar 03, 2010 | Televison & Video
Where can I find a power cord for simpletech
Hi, I think I found one for you 5V AC DC power adapter for SIMPLETECH 96200 41001 075 250GB USB hard... . If it is correct, it is OK to just find ANY power cord with Output Voltage: 5 Volts DC and Amperage: 1 Amps. It just need to fit in.
Sep 21, 2014 | SimpleTech 250GB USB2.0 7200 RPM External...
Prolink h5201
No. You must use a 5V ac adapter/power supply.
But are you certain that you need 5V ac to power your modem ? Where are you located Jane ?
22.April.2014
Feb 16, 2014 | Computers & Internet
Replacement ad/dc power cord
you can get a replacement ac/dc power cord for durabrand portable dvd player model # PVD-707 here;
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Dec 11, 2008 | Durabrand PDV-705 Portable DVD Player
How do I charge the philips mp3 player?
Connect the supplied AC/DC adapter/charger to the 5V DC jack on your hdd and the power supply. The AC power icon will indicate on display showing that the Jukebox is now adapter operated. It takes 4 hours to fully recharge the hdd and once the battery is recharged fully, the jukebox can play up to 10 hours of music on the move
Dec 30, 2007 | Philips HDD120 MP3 Player
Imation 02395 Ml410bk Memorex Elec Portable Line-in Stereo Speaker Logo
111 people viewed this question
Top Imation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Imation Audio Player and Recorder Expert? Answer questions, earn points and help others
