Question about Health & Beauty
Why does by century battery charge go from charging to cutting off. meter also goes from fully charged to charging
    Problem Solver:
There are several causes of such, but the most likely is that one of the batteries is not able to charge in the series. If both batteries are good but one has gotten so low it can't regain it's charge while in the series, you can disconnect the batteries, and charge each one individually, on a 12 volt battery charger, and this will correct this issue, for a time. If one of the batteries has failed, and can not hold a charge, it will have to be replaced.
Posted on Nov 29, 2014
  • bluelight969 Nov 29, 2014
    If one of the batteries has failed, and can not hold a charge, it will have to be replaced. DB
SOURCE: battery wont charge
The batteries are probably worn. Age, failure to completely charge, frequent discharging to below 50% of charge, completely discharging, and heavy use all contribute to wearing out a battery. The most common symptom is the one that you have; the battery will not completely charge.
Posted on Nov 10, 2008
  • 175 Answers
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
Posted on Jul 09, 2009
  • 103 Answers
SOURCE: Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
Posted on Nov 10, 2009
supertech6
  • 513 Answers
SOURCE: new batteries does not seem to fully charge.
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Posted on Apr 02, 2010
  • 175 Answers
SOURCE: Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
Posted on May 23, 2010
How to check charging system on a kohler 17.5
This is an easy check if you have a cheap, simple volt meter. It's much better to have an old fashioned needle meter rather than a digital. The needle is more sensitive, much quicker, and makes a clearer diagnostic tool. But not to worry, for you fancy folks a digital still works (sometimes the results are not as clear).
  1. Set the meter to DC Volts.
  2. Attach the red and black leads of the meter to the positive and negative posts of the battery. Most modern day digital meters don't care if the polarity is correct or not. However, if you have a needle meter, best to put the positive of the battery with the red wire of the meter; otherwise the needle will not be happy with you.
  3. Note voltage. It should read near13 volts if the battery is good and fully charged. If it reads below 12 volts it needs charged or it has bad cells. If after charging a few hours, the voltage is still below 12 volts then the cells are bad, replace it.
  4. Turn the key to crank the engine while keeping your eyes on the meter. Whether the engine cranks or not, the meter should not fall much below 11 Volts. If it falls below 10 volts or worse yet below 9 volts, the battery has a bad cell or two. Replace the battery, charge it, and repeat the test.
  5. If the engine starts, rev it up and watch the meter.
    1. If the charging system is working the voltage on the meter should quickly rise above 13 or 14 volts.
    2. If it rises up strongly towards the 14 volt range this indicates the charging system of the machine is working.
    3. If it plays around down near 12 volts you are reading the recovered voltage of a good battery, but the charging system is not working.
    4. If it simply stays below 11 volts, the battery and the charging system are both suspect. Replace the battery first. Fully charge it, and then repeat the tests before worrying about the charging system.
Note:if the battery falls below 9 volts the fuel cut off, a black cylinder on the bottom of the carburetor (if your model has this), will cut off the gas supply to the carburetor.
Mar 15, 2015 | Garden
On my unit the guage does not seem to move upward as the battery charges or is the line to the far left indicate a fully charged battery
The meter on the charger indicates how much power the charger is putting out. The far left is zero (0) output, meaning fully charged. There should be numbers on the meter.
May 30, 2011 | Schumacher & Fast Charge Starter Charger
I have a jet3 ultra that has never been used. In October we bought new batteries. It worked;however, we have not used it or charges it until now. The omnimeter reads 0 and only the one red light shines. ...
amy why did you not keep the batteries charged? even new batteries have to be charged before use. Now plug in the charger and look at the meter with the charger plugged in the meter will show some reading around 4-5 amps. Let the charger work overnight when you get up in the morning fully charged the meter will read zero. Turn on the chair and all the battery lights should be lit. If after charging over night you are still getting one red light then you blew 170.00 and no amount of charging will bring them back. Sorry I wish I had better news. If you replace the batteries charge fully before use and then use the chair some each day and charge nightly for 20 days this will break in the batteries and get them operating at 100%. If you then only use the chair sometimes always put it up fully charged and charge at least once a week If you use the chair for that day charge overnight and it will be ready to use again when you need it. If you are going to leave the chair unattended for 6 months then fully charge the batteries and disconect them from the chair until you need it again New batteries every 6 months can get expensive Hope this helps you
Apr 17, 2011 | Health & Beauty
How to tell if battery is full charged before using it.
The easiest and best way to test any battery is with a volt-meter.
http://www.northerntool.com/shop/tools/product_12496_12496
The link above is for a multi-meter. These are inexpensive and are an extremely useful tool to have. For about $15-20 you can buy a meter which will test AC/DV voltage, resistance/continuity and often diodes and/or transistors as well.
A fully-charged 12v battery will give a reading of 12v (or very close to 12v) on a volt-meter when it is fully-charged. 6v batteries should read 6v, 1.5v batteries should read 1.5v, etc, etc.
If the reading is lower than the power output of the battery, the battery is either not fully-charged or one or more cells may be damaged. If cells are damaged, you will never get the full 12v output from a 12v battery.
There are other ways to test batteries but they are less accurate. It's possible to use a battery charger, but you can only use this to determine whether a battery is fully-charged if the battery is known to be good. A fully-charged battery should draw 0 amps on a battery charger, but a damaged battery may also draw 0 amps so this is not a good test.
Basically, I'd suggest you get yourself a multi-meter. You be glad you did!
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Mar 11, 2011 | 300 Amp Battery Jumper with Air Compressor...
92 yj gauge show not charging disconnect battery engine dies but check with meter shows charging if you disconnect the battery should it keep running if its charging.
It is NOT good to disconnect the battery with the engine running as you could destroy the computer!!
Charge volts with digital multi meter shouild be 13.8v-14.4v...if low then battery must be fully charged to check charge rate.
Mar 10, 2010 | 1992 Jeep Wrangler
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
My 2000 harley davidson motorcycle wont hold a charge
Get access to the battery terminal posts, star the bike and set the meter to "Volts DC". Touch the leads to the positive and negative posts and see what the meter reads. If the voltage is between 13-15 volts then the bike is charging, if thats the case the bike is charging but your battery is hooped. Start with that and if the bike isnt charging then write back again for trouble shooting instructions.
Jun 11, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Power capacitor
From the Legacy Manual:
The supplied charging bulb(included
in the package)is used when initially
charging the Cap. the charging process
is accomplished by connecting the
charging bulb in series between the
battery’s positive post and the
capacitor’s positive terminal.(plese
refer to the diagrambelow). it is very
important to follow this process to
eliminate the possibility of damaging
the cap/battery, and other audio
devices. The charging process is
complete when the voltage of the
capacitor reaches the same voltage
as your vehicle’s battery. This process
will take a matter of seconds to
complete. You can use a voltage meter
to check the voltage across your
battery and cup .when the voltages
are the same on both(cap and battery),
the cap has been fully charged. The
charging bulb actually eliminates the
need for the volt meter, when the cap
is fully charged (cap and battery have
same voltage) the bulb will go either
dim or fully out.
Feb 01, 2009 | Legacy Lca280sl 2.8 Farad Digital Power...
Battery doesn't work
Replace the adapter the power cut caused it to blow out......aways happens it is the power serge that cause the fault.
Oct 12, 2007 | Toshiba Portege S100-S1133 Notebook
Health & Beauty Logo
119 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
