Question about Wells F67 Dual Countertop Electric Fryer
One year old fryer and melted the solenoid, replaced it, did it again. Put in a new thermostat still trips it. Whats next?
    New Friend:
  • 29 Answers
Hi-heat safety switch
Posted on Nov 27, 2014
2 Suggested Answers
kebah
  • 684 Answers
SOURCE: fryer heats up but does
Hi there.
You may need to calibrate the new thermostat and in doing so, you will need a calibrated thermometer with sensor dipped in oil at about one (1) inch above the fryer thermostat sensing bulb.
Record the cut-off temp (when indicator light goes off) and compare it with the thermostat setting.
The thermostat has a calibration screw ( - ) recessed in the middle of the shaft, you will see the when you pull off the thermostat knob. this calibration screw can be turned by a precision screw driver, turn clockwise to decrease the cut-off temperature ; turn counterclockwise to increase the cut-off temperature.
Just make sure that the unit is preheated or have cycled at least 5 to 8 times and the oil is new before performing the calibration.
Regards.
Posted on Jul 15, 2011
Why does fryer shut down when it hits 200 degrees
The thermostat? If your thermostat works normal, it should switch off the heater when the temperature is reached. Perhaps there is a last security, when it really gets to hot it will trip and you have can't use it till that is repaired. Perhaps you replace the thermostat. Or if a new thermostat is almost as expensive as a new fryer, buy a new fryer.
Jul 17, 2014 | Imperial Kitchen Appliances - Others
Water heater
Guessing that you have 240Volt residential non-simultaneous electric water heater? And that you have 30 amp breaker and 10 gauge wire. And that water heater is located within 100 feet of breaker box. And there are no leaks running hot water out of tank. And that you installed fully brand NEW elements of same wattage as old elements. And that fully brand new thermostats were installed, and wiring exactly duplicates wiring that was present before. And that factory-insulation was re-installed over elements and thermostats.
1) Guessing the 'hot water shut off' means the ECO red reset button located on upper thermostat keeps tripping and cutting off electric power to water heater?
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
http://waterheatertimer.org/How-to-test-water-heater-wires.html
2) If the ECO is tripping, then water is getting too hot, or there is shorted wire located near the upper thermostat, .
Typically replacing both thermostats and replacing elements will solve this problem .... assuming that new thermostats and elements are good, and wiring correct.
Double-Check your wiring on upper and lower thermostats.
Test wires for short.
Make sure factory-insulation is re-installed over thermostats so cool room temperature will not affect temperature reading.
Check that thermostats sit flat against steel tank.
Many short draws hot water can also cause stacking event that will trip circuit breaker.
3) Add comment and say what you find using checklist above.
Be careful to explain findings fully, using same words found on links above, so illuminated diagnosis can be made.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 28, 2012 | Water Heaters
Cant get my fryer to work basically. Thermostat is turned to a high temp but still nothing. pls help!
You need to replace the Thermostat. (Sometimes it's the solenoid prior to the thermostat that caused the thermostat to burn out, if that is the case, you will need to replace both, or it will just burn our your new thermostat.)
Nov 24, 2011 | Gaggenau VF 230 Deep Fryer
Put a new valve in a imperial fryer pilot lights and stays lit but when i turn the t-stat on it shuts off
The reason is the pilot generator will hold the safety magnet but it won't operate the solenoid.
It is old and weak.Ain't putting out enough power to operate the solenoid. Get a new generator
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 16, 2011 | Imperial IFS40 Deep Fryer
Fryer is cutting out after certain temp and tripping hi limit. I replaced Hi Limit, Thermopile and Thermostat and it worked great for two days and then kicked out again, tripped Hi Limit. I'm baffled...
Hi there
Hi limit will trip at 450F.
Check your thermostat setting, then check its calibration, this way you will be able to verify where the problem is.
If the setting and calibration of the thermostat is good, check the hi limit sensing bulb, it should not touch the fire tube because if it does, it will sense high temperature and will cause premature tripping.
Regards.
Jul 11, 2011 | Pitco Frialator SG14 Deep Fryer
Unit overheats. Replaced thermostat and this did not resolve the problem. Please advise. Thanks for your help !
Hi there.
If overheating trips the hi limit and as you said, the thermostat is new, the first thing to consider is the wiring connection or is it properly wired?
You can download Owner's Manual for your fryer containing wiring diagram which you can use as reference at http://www.wellsbloomfield.com/wellsmanuals.aspx/
Regards.
Jul 08, 2011 | Wells F-49 21148 Deep Fryer
Maytag top freezer MTF2176hr melt down
Sounds like a bad cold control ( thermostat ) The switch that cuts the fridge off/on .
Jul 16, 2009 | Refrigerators
Dishwasher trips the fusebox.
You have a obvious short circuit.
Remove the lower panel and inspect the drain valve solenoid attached to the pump beside the motor.
These GE solenoids will stick and melt causing a short circuit.
If not that, open the front panel and inspect all wires for a break.
May 26, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Head Banger
i havent heard of this but these suggestions may help you.the hi-limit is preset at the flash point of oil (depending on the oil) around 500-525 degrees.if the hi-limit is tripping out either the thermostat is out of calberation,the hilimit itself is bad or the hilimit/thermostat bulb arent secured to their respective bracket.if you have a meter or thermocouple tester to test the actual heat of the oil (or a half decent themometer).set the temp dial to 200 degrees,once the burners go out put the thermometer/meter into the oil.the temps should match 20 degrees over/under is acceptable.if not the t-stat is bad.if this is ok goto the hi-limit and jump it out,there should be 2 wires take them off and connect them directly.set the dial to 350,wait until the burners shut off and test the temp of the oil again.if it matches your hilimit is bad.let me know.be careful when you do this because if the t-stat is bad the oil may ignite.if you see a lot of smoke cut it off.let me know.
Jan 11, 2008 | Pitco Frialator SG14 Deep Fryer
Wells F67 Dual Countertop Electric Fryer Logo
63 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Raymond Koonce
Level 1 Expert
Dennis Boxerman
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
