Question about Garden
Leaf blower was running great, but cut off and will not start
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Did you have the Fuel to oil mixture correct? I'm assuming it's a 2 stroke engine on your Blower
Posted on Nov 25, 2014
boscia
  • 163 Answers
SOURCE: gas blower craftsman leaf older modle
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Posted on Dec 05, 2008
bbreton
  • 437 Answers
SOURCE: mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Posted on Nov 02, 2009
  • 15 Answers
SOURCE: yard broom leaf blower will not stay running I
It seems that the carb is not getting fuel. It could be a cracked fuel line. The fuel priming bulb could also be cracked/dry rotted. Possibly the fuel pump in the carb is bad. The carb is rather intricate and not something anyone without training should try to repair. The overhaul kit will cost $15 to $20. I suggest you take the blower to a repair shop.
Posted on Apr 19, 2010
Testimonial: "Thanks will do"
SOURCE: loss of power leaf blower - gas
Had the similar problem- start with removing the exhaust intake plate 1st--- clogs with super fine dust initially then larger particles... Mine was completely clogged- cleaned er' out now she blows like the wind!
Posted on Jun 11, 2011
Husqvarna 350bt blower runs great but goes dead at half tank of gas.
I had a Husqvarna saw with a similar issue. Turned out to be a deteriorated fuel line. There was a hole in the line, sucking in fumes then cutting out the engine.
Dec 05, 2014 | Husqvarna 350BT 50cc Backpack Blower 50cc,...
Mb 3200 gas leaf blower will start when choke
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
Toro gas leaf blower erratic engine performance
hi
change the sparkplug or seals.
bye
Oct 04, 2009 | Garden
Wont start, not getting fuel, checked lines,carb and used starter fluid, runs but won't continue to run
You may need to do a more detailed cleaning on the carburetor. I like to use a Den Tek Brush, (used for cleaning teeth), to get into the small ports. They work great for this job. You may also need to check the small screen in carb. It gets blocked with debris.If you need further assistance, please contact me.
Jim
May 17, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Loss of power leaf blower - gas
Mar 30, 2009 | ECHO, Inc. PB-251C Handheld Blower
Homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Mar 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Engine cut out
On the bottom of the carb. there is a plate held on by one screw, take that plate off and very lightly clean the screen on the carb with a bread tie wire, this worked very well for me. Mine runs great now:)
Nov 08, 2008 | Homelite Consumer Products Backpack...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
