Question about Home Security
I have a Honeywell DT-720B motion sensor that is set to a straight beam. How do I change it to a wide spectrum for my alarm system?
2 Suggested Answers
  • 49157 Answers
SOURCE: How do I adjust a Honeywell motion sensor from a
there should be 2 small adjusting screws on the unit. One adjust what you want and the other adjust when the light or sensor works.
Posted on Nov 14, 2014
How do I replace a low battery in motion detector for my Honeywell wireless alarm system?
Look on the bottom of the sensor, there is a tab/button press it in and pull outwards from the bottom of the sensor, it will hinge upwards and detach.
Inside you will see the battery which is easy to change..
Replace the battery - refit the sensor top first and push in at the base, Job Done.
Jan 23, 2017 | Honeywell Home Security
New apartment with A honeywell ademco 4110xm. I connected power and got master code. I get CHECK 05 and ALARM 06. Typing the code and OFF disables the ALARM 06 error, but Check 05 remains. Any help?
It is telling you that a zone is not working properly or is open. Ex. door not shut, window not shut. Something moving in front of a motion sensor. Fin out what zone 5 is and that is your problem for arming. Could be a battery if this is a wireless system.
Jan 18, 2016 | Honeywell Home Security
How do I adjust a Honeywell motion sensor from a straight beam to a wider spectrum?
Nov 13, 2014 | Cars & Trucks
How to disconnect
Ok their might be a screw on the unit to open it up. Once it is open their is 4 wires on it one for power + and one for ground - disconnect them and cap them off.
Ed
Aug 25, 2014 | Honeywell Intellisense DT-900 50 X 40 to...
As per request. re: reset/fix indoor motion detector.
on all the Honeywell or Ademco wireless motion detectors I have worked on the light will not come on with the cover in place, it is set that way to conserve battery life. If you want to be sure it is working properly arm your system and wait at least 4 minutes before walking in front of he motion then walk in front of it and see if it trips the alarm.
May 05, 2014 | Honeywell Ademco Apx32en Alarm System...
False alarm
If it's showing alarm and the number 06, this means the panel believes zone 6 went into alarm. What's on zone 6, motion, door, panic button?
Nov 27, 2013 | Honeywell V15P-WLS - Ademco Vista15P...
False alarm
were is it located. it maters with a motion they work on infer red motion. If it is near a heat source or anything moving it will set it off.
Jan 22, 2013 | Honeywell DT7235T DUAL TEC Motion Sensor
Alarm keeps going off
The alarm might be setting to sensitve motions detecting mode,this setting,if u come close to the car or slicely taps or touch it the alarm will go off.This setting it is not good for the car as the motions detection sensors over time will get old and will go off at anything causes some presure even slice wind just past by the car.Take ur car to the alarm tech. check it out for the motions detection sensors again change to mormal setting not sensitve mode this setting mode it actually the best,because the normal setting the door have to open before the alarm will go off.Or the alarm tech have do a replacing a new alarm unit it self,because the detection motion sensors can not do a readjustment or resetting the setting any more.
Oct 03, 2011 | 1995 Toyota Previa
Our Ademco 6160 PL3 alarm system keypad has an error message
It is located inside a tan colored metal box 12"wide by 15" tall and 4" deep; unless it is flush mounted, then only .5" deep. inside you will most likely find a 12 volt 4 or 5 or 7 amp hour battery. Note; the door may have a lock on it. I have found the key on top of the box, in the lock, and unlocked. The box could be located anywhere but, many times in closets, utility rooms, garages, crawl spaces, etc.
Nov 01, 2009 | Honeywell 5804 Ademco Wireless Security...
Home Security Logo
64 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
