Question about Watches
What can I do, just purchased a watch and is not working properly.
I purchased a watch for my husband on October 4, it stops working after 3-4 days. I did not buy the extended plan that AAFES offers since we have had several Fossil watches in the past and all have been very good quality watches. We are with the American forces living in Germany and have an APO AE address witch works as if we were living in USA.
    Master:
  • 253 Answers
Honestly if it were me, I would simply return it to where it was purchased.
Also know that anything purchased via a credit card is usually protected.
You can call the credit card company and tell them the item is defective. They will ask if you have tried to remedy the situation with the seller, and go from there.
I hope you get your refund. God Bless and Thank you and your husband for your service.
Posted on Nov 13, 2014
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Posted on Aug 24, 2007
  • 17 Answers
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
Posted on Jul 30, 2008
escapement
  • 2334 Answers
SOURCE: watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
Posted on Jan 10, 2009
SOURCE: Instruction Manual for Fossil Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
Posted on Feb 21, 2009
SOURCE: g force radio controlled watch instructions
I have an ehoward&co radio controlled wrist watch and I'm having difficulty in setting the correct time on the dial. can you help?
Posted on Aug 14, 2009
The second hand will not re-set to zero. It has stopped. The watch works perfectly during the day apart from the second hand not moving, but , the watch stops at 11.15 at night. When I get up in the...
This is a symptom of what is usually several possible issues:
1) The most common is that the battery must be changed. Insist on Energizer batteries only (as they do not leak) and visit your local Certified Master Horologist for assistance in changing the battery and resetting the watch.
2) The movement must be serviced every 3-5 years by a qualified professional. Dust and debris can cause the symptom of stopping and starting the movement. If you have owned it for less time than this, remember that the watch may have been manufactured and in the retail location longer than this period of time before it was purchased.
3) The movement is defective or damaged. If the watch is under warranty, and it was purchased through an authorized dealer, Armani will take care of this issue for you at no charge.
To properly assess this issue, I recommend taking the first step, as a CMH also has the proper tools to test the movement and battery to determine the best next course of action.
watchandpen
Feb 25, 2011 | Giorgio Armani Emporio Armani watches...
I found a rollex winner 24. It looks original. The only question i guess is that it has roman numbers arround but number 2 looks bakwards. could that be possible. Any other clue to determine it is...
As far as I know this watch model did not use Roman Numerals.. the hour marks should be simple single hash markers.. no numbers at all ..
The minute and hour hands should be pointed.. and the minute hand should extend over the edge of the hour markers touching the second markers
The winder should have three dots under the Rolex Crown and there should be s o ring on the stem set in a grove.. that functions .. not for looks.
The registers (three little sweep dials) should not have days of the weeks or any other reference to dates..just numbers.
The "Second Hand" is actually a part of the stop watch function and should be stationary at the noon mark.. it never moves unless activated.
If you remove the bracelet... the Rolex serial number will be engraved very smoothly between the lugs.. not etched..
Finally the best way to find out for sure is to have a jewler remove the back.. (which by the way if clear.. it's a fake).. and examine the movement. This is the best way.. and some fine jewlers that sell high quality watches will do this for free.. there are some good fakes out there.. if you plan on keeping it.. enjoy it as a fake.. if you plan on selling it.. have it verified.. however if I lost a watch this valuable.. I would have posted it in every lost and found medium available.. and offered a reward.
Good luck
Feb 23, 2011 | Rolex Daytona 116520 Wrist Watch
My husband purchased a new PS watch, that doesn't need batteries, but is suppose to stay going by movement. The problem is it stops all of the time if he is not actively moving.
Kinetic dive watches utilize motion, or kinetic energy from watch or hand movement. If there is inadequate movement to keep the watch going.
RECOMENDATION:
1. Involve some much needed physical movement (Physical Training) that will both help the wearer and the watch with the watch being the judge of if he is moving enough every day?
2. Get a battery powered watch.
Number one is a better solution.
Hope this tip helps.
r/
David
Feb 23, 2010 | Philip Stein Teslar Watches
Hello: Watch stops , will not work unless
Most watch company's offer a 2 year warranty on the movement and it sounds like a problem with the movement. I recommend taking it back to the point of purchase with reciept if they can't look it up and most company's will remedy the problem at no cost to you (when it is that new).
Oct 17, 2009 | JCPenney Elgin Men's Diamond Accent Watch
Repair location in my area
Try AWCI.com for someone in your area. I recommend a good watchmaker even for a cell replacement, they will usually clean the case and band, do a consumption check, a min run voltage test and a water resistance test and new seals to keep watch fresh.
Jun 13, 2009 | Wittnauer Laureate 12R12 Wrist Watch
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
Armitron watch band needs extra links
I just called the main headquarters and they sent me 2 links for FREE!!! 1-800-840-2933 my model # for my watch is 20/1897T1 found on back. Hope this helps :)
Jan 02, 2008 | Watches
Rolex runs down
sounds like you need a new watchmaker, Your watch is designed to be worn 16 hours a day an rested for 8 while you sleep and this should keep it running. there are several different mainsprings that can be installed depending on the age and your activity level. I would be happy to take a look at it for you.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Oct 09, 2007 | Bulova Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
