Question about Clymer Mercury/Mariner 75-275 Hp Two-Stroke Outboards Includes Jet Drive Models 1994-1997 - B724
Why does my mercury outboard idle perfectly but stall out under load?
    Problem Solver:
  • 11 Answers
Your carbs are probably dirty. Remove the carbs and clean out all jets and passages with carbcleaner and compressed air.
Posted on Nov 25, 2014
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
I have a 2000 Mercury Cougar 5 speed (manual)when the engine is warm and i slow down at a light and put it in neutral it stalls or when i turn it stalls, it starts up when i turn ignition. That is the only...
Have your mechanic adjust your idle up a bit sounds like it is idleing to slow.You might want to try some injecter cleaner in your next tank of gas as well sometimes a little dirt or sludge will cause your vehical not to get all the gas it needs when not under a load.
Apr 10, 2012 | 2000 Mercury Cougar
Mercury outboard 3.5 motor stalls
not sure here as i normally answer car questions but if this engine is of the new generation and its all electronic then it has to be plugged in to locate the fault .My outboard was playing up like this with loss of power and the dealer wanted a small fortune to repair the pump which feed the fuel injection system so i took it apart and made a new valve for it out of a piece of fishing hook plastic wrapper and a bit of copper wire hook type thing i made and that was about 5 yrs ago and its still running fine
Apr 09, 2012 | Mercury Boating
Smoke coming out of bottom carb on mercury 50hp outboard engine
It's possible that a little fuel vapour come out of a carb on an hot engine that has just stopped.
Does the motor starts again and runs well in higher rpm ranges? Is the stall only when idling? If so, enrich the idle fuel mix ( screw out the idle mix screws half a turn t a time )
Aug 06, 2017 | Boating
3.5 mercury outboard stalls when put into forward
hi take the prop off see if there is anything /string/ between the hub and the housing check oil lvel in g/box /is gear box nice and free if all is ok try it in ware with just a small amount of choke
drain /empty fuel out replace with fresh /correct oil mix
check /change fuel filter/air filter
warm engine up check idle mixture ajustment/tick over speed
increase idle speed slightly/7/800 rpm
hope this helps merlin v 12
Aug 20, 2009 | Light Outboard Motor Boat Bass Fishing...
My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Aug 02, 2009 | Light Outboard Motor Boat Bass Fishing...
Clymer Mercury/Mariner 75-275 Hp Two-Stroke Outboards Includes Jet Drive Models 1994-1997 - B724 Logo
346 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Are you a Clymer Boating Expert? Answer questions, earn points and help others
