Question about Garden
Back of deck gets real hot - Garden
    Problem Solver:
  • 22 Answers
You may have a bad bearing in the spindle shaft, raise in the air, with engine off take the blade and move it up and down, if you have any play the bearing is going bad.
Posted on Nov 14, 2014
Do I need an amp for my 3head sony real to real tape recorder
You do need an amp of some kind. On the back of the deck will be RCA sockets, in the red and white ones you plug a line cable to the audio in sockets of an amp or receiver. The other two sockets are record. They go to the audio out of the amp.
Jan 17, 2014 | Beltronics TEAC W-600R Home Double...
I have a proform 765 ekg and just replaced the motor because the treadmill kept stopping but it still stops and the breaker kicks off and the motor is real hot. any thoughts on why it still stops
LUBE the deck belt and rollers bearing this happen to due the lack of maintenance. see the video attached. Do it with silicone or wax read your manual.
If after you did lube the problem remain, TIME to replace the old board deck belt.
God bless you
Feb 16, 2013 | Proform Quick Burn Pro Treadmill with 12...
I have rusted and worn pulley on my mower deck. I have new pulleys. How do I remove the old ones to install the new ones?
How do they install on to the deck.If they are splined with a bolt holding them then remove the bolt.Sometimes the housing bolts to the frame of the deck with 3 or 4 bolts.Clean the deck and area to be worked on real good and see what kind of hardware is holding it to the deck.Hope this helps.
Nov 05, 2012 | Husqvarna Garden
Where can I get the back plug for it?
Any Car Audio Dealer,That sells JVC decks will be able to get one for you, As long as the deck is not hot,
Nov 01, 2012 | JVC Kd-r320 Am/fm/cd Receiver
How do i detach the cassette holder door of my Teac W 600R?
If it does not slide up and off then some models were not made to have the cassette holder taken off and they are a real pain to get back on due to plastic and springs. Why do you want to take it off?
Feb 02, 2011 | Teac W-600R Single Cassette Deck
Husqvarna YTH 2448 mower PTO switch is getting hot and melting the plastic internal parts. Any ideas on what is causing the overload? The mower deck will shut off when the switch melts and the push/pull...
The problem with an electric cluch is that when the engine is running without the clutch engaged the clutch can turn into a dynamo which then passes power back up to the switch, most machines will have a diode close to the clutch in the wireing to stop the current flowing back to the switch, so i guess the diode is bad on your machine and power is flowing back to the switch and melting it,
Nov 08, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Replace capstan belts
(Unplug the unit before doing the following!)
Pull the top off (8 screws). On the back of each deck you will see a motor (silver cylinder 1.5"Diam x 1.25"Long) mounted to a removeable plate. It's kind of tricky, but... Loosen the bottom two screws securing the motor mounting plate (not the motor itself) to the rest of the deck. Then completely remove the top two screws, so the moter and plate fold away from the rest of the deck. With some care, you should be able to remove the old belt and slide the new belt over the capstan flywheel and motor pulley. Fold the motor assembly back into place and secure the screws. That should do it!
Note: I used a jeweler's screwdriver and needle-nose pliers to turn the screws on the motor mount. This is real fun with all the wires in the way, but it is possible. I Also pulled the screws on the power transformer, to move it, so I could get at one screw for deck #1.
BY THE WAY: I'm ready for new belts myself, and haven't been able to find a source, except in germany. Any ideas??????
Mar 22, 2009 | Audio Players & Recorders
Heating up
Suspect short circuit inside if output performance is below satisfactory level and current drawn is 20% or more than rated.
Shanks1
Nov 14, 2007 | Sony CDX-M800 CD Player
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
