Have a Bryant model 394ga1024075 when I call for heat the pilot comes on but when the gas valve comes on it lites for a second then gos out. Ive replaced control board , spark igniter gas valve and pi
Have a Bryant model 394ga1024075 when I call for heat the pilot comes on but when the gas valve comes on it lites for a second then gos out. Ive replaced control board , spark igniter gas valve and pilot assm. still same problem. there are no roll out switches on this unit
    Novelist:
  • 166 Answers
Check the gas pressure and/or gas line to see if it's it plugged
Q. does it pop when it goes out???
Posted on Nov 14, 2014
SOURCE: goodman ac/gas furnace unit mdl. # gmp075-4
i HAD THE SAME PROBLEM, TURNS OUT IT WAS THE FLAME SENSOR, CLEANED IT, AND ALL WAS GOOD
Posted on Dec 13, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMP075-3 ignition problem
OK, if the furnace is not lighting for even a few seconds, you have either a bad gas valve, bad wire, bad control module or no gas. The pressure switch is not the issue. Check all wires to the gas valve and look for 24 volts across them when the ignitor glows and you hear the click. Then test for 24 volts to ground. It could be a bad ground wire.
Posted on Oct 21, 2008
  • 6 Answers
bad board,i have had several board failures on goodman
Posted on Dec 31, 2008
SOURCE: Ducted heating unit blows cold air and fan is always on..
that s correct the control is done by the thermostat stop the heating up to your set point and restart if the medium temp is under the set point
if this sequence fail means
- no power to the control element or is defective
thanks
Posted on Apr 27, 2009
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
Posted on Dec 11, 2009
Bryant furnace
Check gas valve is not on pilot only check air filter is clean check connections to gas valve .
Oct 10, 2017 | Heating & Cooling
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
Heats fine when gets up to temp gos down to pilet will not lite back up tell i tap the valve
you could have a dirty pilot. these run on 750 mv. it takes around 200 to run the main burner. check to see if the pilot is sharp and blue or lazy and yellow. loose or dirty connection on the wiring will also cauce this problem.
Jan 29, 2011 | Empire DV-215 Direct Vent Natural Gas...
VN18TB PILOT LITE GOES OUT STAY LITE TILL HEATER COMES ON AFTER THE HEAT RUNS AND TURNS OFF THE PILOT LITE SHUTS OFF NATURAL GAS VANGUARD
Sounds like a weak thermocouple. With the extra heat of the main burner running it can keep the pilot solenoid open...without it it fails shut. Try replacing the thermocouple. (small rod the pilot flame burns against with a skinny copper tube going to gas valve).
Jan 04, 2010 | Heating & Cooling
Laars lite 2 pool heater burner not lite
If the pilot flame is not strong enough, it will not tell the gas valve to open, or if the gas valve is not getting the signal to open, it won't. Check all wire connections at the thermostat and gas valve. Check ground wires. Clean the pilot light and flame rod.
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Bryant 36E93 gas package (pilot won't stay lit)
If your unit has a thermo-coupling this is most likely the issue This little sensor sends a milli-voltage to the gas valve telling it to keep sending gas for the pilot since its lit and all is good. They wear out and the gas valve thinks the flame has gone out (whick is hasnt) and kills the gas flow.
Jan 21, 2008 | Bryant 462AJC021BA Air Conditioner
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
