Question about Klimaire 9,000 Btu PTAC Packaged Terminal Air Conditioner & Heat Pump - with 3kW Backup Heater Wall Sleeve & Back Grille 220 V
The control panel on my unit KTHM009-E3C2 flashes all lights and gives a display of 8.8. when we try and run the heat. it automatically shuts itself off. What could the problem be. It has been runni
Once this happened now it will not do anything except flash all lights and beep.
  • 101 Answers
Check that the controller is set for degree F not Celsius, cyccle breaker off and back on, change the batteries on the remote controller.
http://www.klimaire.com/media/klimaire_product_pdfs/503bfa1f27c95_-_SERVMAN.pdf
Posted on Nov 26, 2014
G 2582 scvi
make this test and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Flashing indicator light
follow the next steps and fix it. God bless you
Check Fault Codes
Drain Pump
Touchpad
Jul 06, 2013 | Dishwashers
G1022
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jun 13, 2013 | Miele Dishwashers
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
Selection Buttons on GE Cafe Dishwasher
Flame light flashes after unit runs for awhile.
Check for spark and clean your plug. If you have good spark it's one of two things, the high heat limit control or the flame sensor, my guess would be the flame sensor.
Jan 16, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Klimaire 9,000 Btu PTAC Packaged Terminal Air Conditioner & Heat Pump - with 3kW Backup Heater Wall Sleeve & Back Grille 220 V Logo
95 people viewed this question
Top Klimaire Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Klimaire Heating and Cooling Expert? Answer questions, earn points and help others
