Question about Hoover Upright Steam Cleaner Shampooer Tank
Hoover carpet shampoer upright F5915-900 the brushes in the brush Bar do not turn to shampoe the carpet
The brushes do not rotate to scrub the carpet
  • 599 Answers
There should be a rubber belt that turns the bar. The rubber belt has broke, or is so jammed up with carpet fiber ,string , hair, etc. or it has just worn out and needs to be replace. GOOD LUCK FRIEND.
Posted on Nov 13, 2014
Testimonial: "there is no belt, its a shampoer, and not belt driven it has a small square plastic leg that makes the brushes turn, but I could not find how"
  • sstoth Nov 15, 2014
    It's run by a combine, and when they installed the motor under warranty, something want wrong, but now Hoover can't find any claim under the warranty repair??? I used it a couple of times and the Motor burns up, now this, pease of junk they stopped making, I know I won't be buying Hoover again EVER.
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
I fitted a new belt. Green light is on so brush is spinning. As I lower the head the brush slows to a stop as it contacts carpet.
There are much quality differences in belts but the foot pedal with arrow is made to set the hightbecarefully because of easy broken pedals . but if the brush is setting on the deepest stand then its not rotating anymore and the brush stands still. its very easy how you can disassemble the brush and can place them in 3 differend levels in height ? on the grey bearing holders outside of the brush there are 3 different indications l and ll and lll the best is to set so that the carpet if its a thin one the brush must setting just lower then the suction mouth so that the brush are more coming out so deeper come out of this suction mouth so that the suction mouth has made a little more distance from the carpet because when the brush rotate to deep insite the suction mouth .1 the tension of the belt on the brush is lower and .2 the suction mouth sucks vaccuum on the carpet and the brush doesnt rotate because of the force of suction power, play around with the different heights you find the right level.
Apr 04, 2014 | Kirby Vacuums
How to clean car carpets?
Rinse the plastic down one more time with the hose, and then dry with a towel. Spray upholstery with cleaner. Turn your mats around so the fabric side is facing upwards. Purchase a carpet cleaning formula, or use laundry detergent.
Jan 19, 2014 | Heating & Cooling
Dc41animal leaves obvious tracks on beige carpet
Hi Alan, it's Jack at Dyson.
Like all Dyson upright vacuums, DC41 Animal includes a motor-driven rotating brush bar. This includes stiff nylon bristle tufts which sweep into the carpet pile, agitating out dust, grit and stubborn pet hair. This will also have the effect of raising the carpet pile where it's been trodden down from daily use - this is what causes the tracks you've noticed. You can see how DC41's brush bar and cleaner head are engineered to work in the video I've attached.
It is possible to turn off the brush bar using the silver brush control switch next to the red on/off switch. However, the brush bar is an important factor in effective carpet cleaning and we would always recommend vacuuming carpets with the brush bar turned on - with the exception of delicate carpets or rugs.
It does sound like your machine is working correctly, in the way it was designed. I hope this information is useful to you, but if you would like some further advice, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 09, 2013 | Dyson DC25 All Floors Bagless Upright...
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Upright Steam Cleaner Shampooer Tank Logo
224 people viewed this question
Top Hoover Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Hoover Heating and Cooling Expert? Answer questions, earn points and help others
