Question about Refrigerators
Werecan i buy a control valve for a malcan hiost
Thanks bill
  • 579 Answers
Try replacementparts.com with your make and model #.They may be able o help you. GOOD LUCK FRIEND. GOOD LUCK FRIEND.
Posted on Nov 13, 2014
Werecan i get a manual
Chaparallel Motor sports San Bernardino Ca. cheep
Mar 31, 2016 | Motorcycles
EGR Code
I had simular problem on 1996 Mercury Marque. Mine was stopped up exhaust port under engine heads = remove heads, clean, replace head gaskets. Also possible that you have a problem with EGR controls, that is due to bad control or vacuum hose off. What does engine analyzer say? Mine was very confusing, listed all kinds of EGR control faults.
Thanks and Good Luck,
Bill
Aug 17, 2012 | 1997 Mercury Cougar XR7
Old house with old water cylinder, water pouring out of the spout and larger than normal electricity bill?
Hello grant.... You must stop that water flow immediately or your bill will be even larger next time it arrives. If the water is pouring out of the spout attached to the pressure relief valve you may simply need to replace that valve. To do so, turn off the power to the tank and use a wrench to remove the pressure relief valve. GO to any hardware store and get an exact replacement valve and a small tube of plumbers pipe dope. Dope up the threads and install the new valve. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | Heating & Cooling
I have a 2003 VW passat, its reading that cooling and turbo underboosted code, I took it to a shop that handles with foreign vehicles and they are unable to help me, I have chaged everything possible andmy...
There is a boost control valve that can cause problems. It can go bad. It has 3 vacuum hoses attached to it to change vacuum direction to turbo and wastegate valve. The boost control valve can go faulty or stick and not allow boost.
Aug 18, 2010 | 2003 Volkswagen Passat
No lights on the circit board What is the output voltage for the transformer tamura 3A0172-01 26D285H I have 2.9 1300 series Thanks Bill
The output on the transformer is 12 vac make sure the Bin control is closed the toggle in the Ice position and also check wash valve handle is closed (micro switch behind handle)
Dec 07, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Maytag neptune shutdown
You need to first check your water inlet hoses & make sure they are not kinked or plugged.(verify by disconnecting hoses & opening to make sure water flows. If ok. Then check for cold water operation at fill valve. If no cold water after a few seconds then the problem is the water fill valve. If this doesn't help. Post findings for further troubleshooting.
Bill
Apr 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water level
YOU CAN EITHER CONTROL THE LEVELS ON YOUR WASHER BY LOAD SIZE small=less water in the machine, or you can turn your water valves on clockwise
Jan 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
