Question about Dryers
Found snapped belt at bottom of dryer
How do I fit New one
  • 4 Answers
You will need to remove the front of the dryer. This process is easier for some models than others. You will need to take the lint trap out on the top. Then remove the two screws that hold the top panel to the lint screen holder. After there are two clips between the top panel and front panel about 3inchs in from the outer edge for the appliance. Push them in with a flat head screwdriver or a putty knife. This should reveal about two or 4 screws that hold the front panel on. Remove these screws and the panel should lift out.(Note: there will be two wires for the door switch). (Caution the drum will fall out at you a little bit.) Remove the old belt. Then put the new belt around the drum and put the drum in place as well as you can. Next to the motor will be a tensioner pulley, you will need to feed the belt through the tensioner pulley and loop it around the end of the motor. (this is easier said than done) But once you have accomplished this you should be able to reassemble the dryer.(Note: don't forget to put the wires back on the door switch) Good Luck
Posted on Nov 14, 2014
  • 1462 Answers
SOURCE: Old DANBY elec dryer DCD411 - drum belt snapped
most belts have the length written on or take belt to a good general spares stockist and see if it can ve matched
Posted on Aug 31, 2008
barkencoa
  • 3463 Answers
SOURCE: how to fit a new belt to a hotpoint condenser dryer TDC 32
My advice to u would be to call an engineer to fix it, as it it involves a complete strip down, and is not an easy job to undertake unless u are prepared to spend a lot of time and effort, I speak from personal experience, so I know what I am talking about.
But again if u think u can do it then good luck, but don't say I didn't warn you!!!!.
Plz rate my suggestion.
Thanks
Posted on Dec 31, 2008
  • 1891 Answers
SOURCE: fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Posted on Jan 02, 2010
  • 8404 Answers
SOURCE: broken belt for clothes dryer LG
Remove the front panel .. two screws probably.
Look for the belt tensioner on the floor when you get it open.
Posted on Mar 28, 2010
SOURCE: Zanussi Dryer TC7114S drive belt snapped and
look on youtube there are lots of videos on this
Posted on Jun 13, 2011
Trying to fit a dryer belt on a trinity bendix tm220w but it has plenty of slack - Double checked it the correct belt for this model
Is there a belt tightener you missed when you installed the new belt.
Check and see if there is one that fell down out of sight . Should have a spring on it if there is one.
Nov 07, 2014 | Dryers
How do i fit a new belt to my white knight cl447 wv dryer
Pop the top (spring clips) remove the front - use care with the wires. Find the belt tensioner on the floor of the dryer. Do a complete cleaning of the inside. Put the new belt around the drum get an assistant to help you hold the drum while you thread the belt through the tensioner and place the tensioner in the tensioner holder slots sin the floor. Put the front back on, snap the top back down.
Allow 2 hours for this job.
Feb 17, 2010 | Dryers
Replacing snapped dryer belt
need to know what make and model machine is. although this is not easy job on any to be honest. But just take your time and take pictures on mobile phone of positions of wires ect. good luck
Feb 12, 2010 | Dryers
Hi i need to fix the belt that rotates the dryer
MOST SERVICE COMPANIES WILL HAVE A BELT, OR RING SIMPSON ON 131350
BEFORE YOU FIT THE BELT MAKE SURE THE CENTRE PULLY IT GOES ON SPINS FREELY- IF ITS TIGHT IT WILL RUIN THE NEW BELT.
Jul 06, 2009 | Dryers
How to fit a new belt to a hotpoint condenser dryer TDC 32
Thanks
Dec 30, 2008 | Hotpoint TDC32 Electric Dryer
Whirlpool gas dryer model # lgr7646eq3
put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Sep 03, 2008 | Whirlpool LGR3624JQ Gas Dryer
Aug 31, 2008 | Dryers
Changing belt
ok hi pretty lady
ok back to dryer, belt go's around drum and tension pully at bottom then to the electric motor
Jan 20, 2008 | Dryers
Kenmore dryer
The pully fits in some groves at the bottom of the motor shaft , the pic should help 9b7b31e.gif
Oct 13, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
