Question about Dryers
Drum on bush tdv6 is not turning but power and heat is on. Where is the motor pulley
    Genius:
  • Dryers Master
  • 1,966 Answers
-The pulley is attach to the motor. I believe the belt is slip off
or broken in this case.
-Unplug it and open the back cover to check the motor & the belt.
Good Luck
mai
Posted on Nov 14, 2014
2 Suggested Answers
  • 291 Answers
SOURCE: The dryer makes a new noise now when the drum is
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Posted on Dec 09, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Heating but drum does not turn
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps Please do not forget to rate me Thank you
Dec 26, 2009 | Estate TGDS840JQ Gas Dryer
Dryer powers up but won't start - smell of electrical burning. Is it the motor bushes? zanussi TC7103W
Electric dryers usually have a motor with a switch that prevents the heating element from being powered until the motor is spinning. In series with this are limit switches to prevent overheating if there is too much lint or too little air flow around the heating element. Also, the motors are induction or brushless. So the smell is coming from the heating element burning off some lint nearby as it reaches the high limit temperature and shuts off. This can be due to two conditions if we can assume the motor is running (has a switch that is closing to power the heating element). The most likely condition is that the drive belt is off the pulley or broken and the drum is not turning. You will be able to tell this easily by sounds or by opening the door to see the drum slowing down. If that's not it, examine the blower which forces air through the drum. There are a lot of variations, so look for air intake and drum exhaust ports that can be clogged with a sock, lint, etc.
Dec 12, 2009 | Zanussi TC7114W Electric Dryer
The drum does not spin, the blower works, the gas will fire up, belts look to be in tact but may be loose?
Most gas dryers have a tensioner on the drive belt under the drum a metal bar with a teflon pully that is spring loaded to tension the belt. Try spining the drum by hand if it spins freely the belt may have come off the tensioner or it may be streched. If it doesn't turn the drum rollers or bushing may be bad. Without a make and moddel # it's hard to say
Hope this helps
Please leave feedback
Dec 04, 2009 | Dishwashers
The dryer hasower but barrel wont spin heat is
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps
Nov 18, 2009 | Hotpoint Dryers
Dryer belt squeaks
Maytags have two rollers that hold the back of the rotating drum in place. The bearings may be going out. with the door open, reach in and spin the drum by hand see if you can hear any indication that the drum rollers may be sticking, stuck, etc.
You can pull the front of the dryer off, then remove the front drum cover and carefully slide the drum forward (while leaving the drive belt in place) you can expose the rollers to see if they are worn or frozen..
You can also check the tensioner pulley on the motor to make sure that's not the culprit as well.
If a roller is bad, I recommend changing them both.. they're cheap and you're already inside the machine...why not?
Good luck...it's not that hard of a job..
Oct 17, 2009 | Dryers
DRUM WILL NOT SPIN BUT DRYER WILL HEAT IT'S A WHIRLPOOL
I have provided a checklist courtesy of; www.repairclinic.com
They also provide repair parts, disassembly diagrams and procedures.
You can also checkout www.homemanagement.services.officelive.com for other appliance help websites.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Jul 13, 2009 | Kenmore 63942 Dryer
Samsung dv4006 dryer belt
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Nov 06, 2008 | Samsung 7.3 Cu. Ft. Electric Dryer
KENMORE DRYER PART NO 696891
are you sure belt not broke remove screws under lint screen and pull top up by releasing clips under edge each corner..is motor running ? also belt may have jumped off idler pulley and motor pulley remove front panel to ck
Oct 24, 2008 | Dryers
Clothes dryer ran ok an hour ago - not now
you may have a bushing problem on the drive motor due to dirt or flint. you can check that by removing the belt and try rotating the motor manually. see if it is easy to turn or not.check also the bushing if you can move the shaft sideways..if it has a slack then its a bushing problem. replace the drive motor.
Feb 03, 2008 | Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
