Question about Sewing Machines
After a long period of no usage, i turned to foot pedal spped to faster pace & began sewing faster. After a few minutes the sewing machine took on a life of its own & wouldn't stop stitching - even when i lifted my foot off the pedal - so i i had to unplug th machi.e to get it to stops! It is an Elna machine. I unscrewed the pedal box to try & unstick the pedal but that hasn't fixed the problem. Any idea what could be causing this?
  • 603 Answers
When you unstuck the pedal, did you also go inside to unstick the contacts (switch). This happens sometimes for lack of use. You may need to replace the contact, but you will see when you get in there. GOOD LUCK FRIEND.
Posted on Nov 13, 2014
  • 6 Answers
SOURCE: Elna Super will not stop running
Bspring- I have found there is a suppressor inside the machine. If you email me at my business email I will forward the info to you so you can repair it your self.
ann@littlegemsales.com
It may take me a while to check for your email but I have Sue59 with the same machine and problem as well so I'm glad to help. Great machines. Ann
Posted on Feb 21, 2008
  • 8 Answers
SOURCE: beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Posted on Apr 27, 2008
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Posted on Nov 12, 2008
Tally Girl
  • 1129 Answers
SOURCE: I have a Kenmore sewing
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
Posted on Jun 12, 2011
SOURCE: foot pedal not working
yes, it is possible that the foot pedal can go out,, it would be a good
idea to have the foot pedal checked at a repair shop to see for
sure
Posted on Aug 28, 2012
Testimonial: "I went to sewing machine store today and the pedal checked out as dying, so ordered a new one. Thx again!"
How do you change the speed on a typical sewing machine2603 ?
most sewing machines are controlled by a foot peddle the harder you press the faster it goes but if this one is electronic it should have another method of slowing it down
Feb 23, 2017 | Sewing Machines
The foot pedal gets hot after a few minutes
It sounds as though the foot pedal is the problem. Maybe a shorted out wire in the actuator (rheostat). When your foot is off the pedal there should be no power running through it. If it has a short then it "thinks" the pedal is partially depressed to the slow position so runs at that speed. If the pedal can be removed/unplugged from the machine, do this and see if the machine stops running.
Sep 07, 2015 | Sewing Machines
Why is my Janome sewing machine model craft 9000 sewing a a slow steady pace?
Do you have a speed limit switch on your foot pedal? My Pfaff does....
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Janome Sewing Machines
My janome feedomatic compact sewing machine gone's wild. As soon as i plugged it on,itautomatically runs at full blast! Can anyone tell me what's wrong? I cant see any auto buttons on
unplug the foot controller to eliminate it as the problem ,however if the machine does not run like mad as soon as you switch it on
without the foot pedal then you have isolated the problem to the foot pedal,it could be stuck on full speed .
Len..
Oct 14, 2014 | Janome Sewing Machines
Toyota sewing machine foot pedal unresponsive then goes really fast.
Try to get another foot pedal. If that works then replace.
Oct 08, 2012 | Toyota Sewing Machines
Why is the motor of my sears kenmore sewing machine model 385.12714 running really slow? The machine has not been used for at least a year or two. We oiled it. It is sewing, but at a snail's pace.
it could be different things
have you checked to make sure the plug is correctly in the machine
one time I was sewing on my necchi electronic machine & it for some reason was going slow like you mentioned & so I started checking different thing & found the cord to the foot pedal was laying in side the foot pedal & it couldn't go any faster untill I moved the cord out of the way
it could also be the motor
& also the power cord & foot pedal
it's possible it needs to be serviced since it's been sitting up so long & since it's sewing at a snails pace
Sep 11, 2011 | Kenmore Sewing Machines
Sewing machine does not sew. Finished sewing something, turned it off, then turned it on a few hours later and it will not work. Light is on but nothing happens when the foot pedal is pressed. Took apart...
Call Singer at 1-800-4singer and ask for their advice, you do not want to void your warranty with not going to an authorized repair service if it comes to that. Good luck
Oct 07, 2010 | Singer 5050 Mechanical Sewing Machine
My janome memory craft 9000 sews without pushing the foot control. It's like the foot control is stuck even if I haven't pushed it. I have to shut the machine off to get it to stop.
Inside the foot control is a component called a supressor.......it is there to reduce or stop the "crackle" interference you may have on TV & Radio when using the machine.
It is not necessary for the functioning of the machine, but when it fails, or burns out, there is generally an acrid smell of burned plastic.....then it runs on by itself and you need to turn it off at the switch to stop it.
Best suggestion if you are not comfortable about opening electrical items, is to take it to a Janome service centre and tell them exactly what is wrong, as described above.. "a burned out suppressor, and the machine now runs by itself"
They ought to be able to do this for very little money really, it is a 2 minute job.......if it has been a while since the last service, you may wish to consider having it all done at the same time, depends on usage and budget in the end.
Let us all know how you get on.
www.bargainbox.com.au
Mar 23, 2009 | Janome Memory Craft 9000 Computerized...
Model 6010 Won't Stop Sewing
I would say that is the computer in hte machine
Jul 18, 2008 | Husqvarna Viking 1
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
