I have a Channel Master amplifier model 3042 to increase the antenna strength on my TV and don't know how to connect it uh it's a Channel Master model 3042
    Master:
  • 464 Answers
Coaxial cable from Antenna to input on amplifier. Coaxial Cable from output of amplifier to Television, VCR or AV Receiver depending on what you have hooked up.
Posted on Nov 13, 2014
5 Suggested Answers
  • 53 Answers
SOURCE: signal strength,picture comes and goes only on one
it is a tuner feed back ring isue there is no way to fix it othere then switching conection types > svid,rca,optical,hdef
in that make shur you dont have input and output confused if using rca or hdef rca method
might sound stupid but disconect all conections and start over map it out on paper then following the mapping checking it off as you go
also could be interferance from an outside sorce
are your cables shielded? if not try buying shielded ones
as this is probly the problem if you have unshiled cables
one tv has better signal rejection then the othere thus the interferance is not seen in one like it is the othere
hope this helped
Posted on Dec 14, 2009
SOURCE: Sharp Aquos E203 No Broadcast now
My LC46D64U just started doung the same thing for any over the air channel that starts with 6. It cuts out for a few seconds about every 60 seconds. Has anyone found a solution for this?
Posted on Feb 28, 2010
gopakumarg43
  • 74482 Answers
SOURCE: After a storm, TV registers
Hello
you haven't given the brand name and model numbe of TV here. yet I posts this solution assuming that it to be LCD tv. You says that the Tv works with converter and not works with digital box. Check the digital box for any malfunction. I can oly give you this much advice as your post does not tell exatly what the fault is. If you want anymore assistance from me, please be clear out the situation you faces now. OK.
Posted on Jun 28, 2011
  • 5188 Answers
SOURCE: How do you connect the antenna and get channels to work?
First make sure that your Input is TV. Use the Input button on the remote (to the right of 0) or on the side of the TV (lowest button). To watch OTA channels, after connecting the appropriate antenna for your location with a coaxial cable to your Antenna In port, press Menu then use the arrows to select the Setup submenu. Press Enter to access the submenu and select Installation. Then select Terrestrial and then Input Configuration. Here select Antenna as your input. Press Enter to save. Then scan for channels by returning to the Terrestrial sub menu and select Channel Program to scan all available channels.
Since digital signals are either sufficient for your tuner to interpret or give No Signal, you need to select your antenna and point it with care. Go to anntennaweb.org or tvfool.com to get information on the stations that you should be able to get in your location. Antennaweb assumes an outdoor antenna but still gives a conservative list of available stations. TVfool gives stations depending on the color code of the antenna (indoor, outdoor, amplified) and their directions. If you are sharing the antenna signal with multiple TVs, you may need an amplified splitter. (If you do have an amplifier, you may want to test removing it from the line and directly connecting the 37HL17 to the antenna. When amplifiers get damaged they can turn into signal filters which block the signal completely.)
If you have the correct antenna, check if another TV receives the stations. If so, you may have a bad tuner on the TV. (Some TVs have better tuners than others and pick up the stations even with lower signal strength.)
I hope this helps.
(I use an outdoor antenna and antennaweb indicates that I should only get the stations from 10 miles away. I actually get those from 30 miles away as well. When I set up a neighbor's TVs with indoor antennas, one only gets the stations 10 miles away and the other gets the stations that are 30 miles away. The two antennas couldn't be rotated to the same direction.)
Posted on Nov 10, 2011
Have lost all channel 2 stations
I assume you are having a problem with OTA channels. On some TVs, if a digital channel doesn't have enough signal strength, the channel list will get edited to exclude it. Have you checked that your antenna is pointed in the correct direction? My external antenna sometimes turns in high winds. Turning it back to the original direction improves the signal strength so that the tuner works. Then go into the Menu and find the Setup or Channels sub-menu to attempt to rescan for channels. (If you add a comment with the model of your TV, I may be able to give the specific sub-menu details for scanning for channels.)
If your antenna has an amplifier, try using the antenna without that amplifier. A few times, the amplifier/splitter attached to that external antenna has been damaged. Then the amplifier becomes a filter and blocks some channels. If you are far enough away from your local station's transmitter and can't receive the signal without the amplifier, replace it.
If another TV receives the stations, the problem is more likely to be the tuner for the TV itself. These can be damaged by a surge from the antenna. The solution is to get a set-top box with an ATSC tuner or replace the TV. Some sites may have replacement tuners (like shopjimmy.com that salvages parts from TVs with damaged screens); however I don't know if they'd have the part you'd need.
I hope this helps.
Oct 15, 2015 | Televison & Video
My tv says no signal on one channel, how do i get that channel back ?
If you are getting an OTA signal, you should check your antenna, any amplifier or splitter and the station's status. The "No signal" message indicates that the signal is not strong enough to be resolved by the tuner.
1) Is your antenna pointing in the correct direction? Outdoor antennas can sometimes turn in the wind. Reset the antenna to the correct direction.
2) If you have a splitter dividing the signal between TVs or other devices, try a direct connection to the one TV that isn't receiving the channel. Similarly, if you have an amplifier in the system, try using the antenna without it. (I have seen an amplifier become a filter for select channels when damaged.) The only solution is to replace the device or omit it. (In my case, some channels require amplification; thus we replaced the amplifier.)
3) Has the station's local transmitter/repeater been damaged? Check their news feed. Towers fall and transmitter components can fail.
You could try and see if another tuner picks up the signal. Some low end tuners are more sensitive to signal strength. If you are getting the station from another source, check with the provider. We recently lost some of the local PBS stations due to problems with the cable provider's feed. Only one TV is connected to the set top box.
I hope this helps.
Feb 13, 2015 | Televison & Video
This is my last time I'm looking for instructions for Channel Master TV amplifier model 3042 and connection instructions
The installation instructions are on the first page: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/659/6593042.PDF
I'm afraid I haven't found the operating instructions for it yet. I was going to keep looking but since you're out of patience I'll stop.
Nov 13, 2014 | Audio Players & Recorders
I had a TV amplifier Channel Master 3042 I need to know how to connect it
This amp can be used with an off-air antenna or a cable box (up to channel 141).
With an antenna: Connect your antenna to the input. Connect the output to the tv's RF (antenna) input (if you're only driving one tv from this amp), or a splitter (if you're driving several tv's).
With a cable box: Connect the feed from the cable company to the amp's input. Connect the output to the input of the cable box.
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
How do i get hd channels with no cable ? just antenna
If your TV has a digital tuner, you can get any HD channels if you use the correct antenna pointed at the transmitter and are close enough to the transmitters. (Antennas labeled as HD are not always appropriate for your location.) Your TV will downgrade the signal to 480i if the TV can't support a 720p or 1080i resolution.
First where do you live? Use antennaweb.org or tvfool.com to determine the correct placement of your antenna for your area/stations. AntennaWeb uses a very conservative signal strength calculation despite assuming an external antenna. Tvfool will give the antenna color rating which is also provided on the antenna package. When properly installed (with no trees or hills blocking the signal), the matching antenna should receive the listed channel.
If you use a splitter to share the signal with several TVs, you may need an amplifier to bring the signal strength to that needed for the tuner to interpret the digital signal. (Note: amplifiers and splitters can fail and the amplifier may become a signal filter blocking the signal; test the antenna strength on a direct connection if there is a problem.)
If you do not have a digital tuner in the TV, you may have gotten an SD digital to analog converter. These are the more common (and available with the government coupon) converters. You will need to get an HD capable tuner to see the full HD signal.
Please add a comment with your TV model and antenna choice for additional support.
(antennaweb indicates that my external antenna should only get the stations 10 miles away. We actually receive the channels from 30 miles away. We use an amplifier splitter to feed the signal to several TVs. I set up two indoor antennas for a neighbor's TVs. One gets the signals from the transmitters 30 miles away and the other from the transmitter 10 miles away. Both get HD from the stations with HD broadcast (not all channels are in HD here). The difference is totally due to antenna placement.)
Aug 10, 2012 | Hisense Televison & Video
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
Feb 01, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I hope this helps.
Nov 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
May 15, 2011 | Televison & Video
GE Model 20GT360 TV and digital antenna problem
Are you connected to a digtal converter or just a digital antenna? If only to an antenna then yes you will most likely pick up one or two low power UHF stations that are still able to broadcast in analog.
Nov 17, 2009 | Televison & Video
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
