Question about Masonry Tools
How to change blades in ryobi 10 inch thickness planer i have 2 jigs explain there use 1 is a gauge im not sure what the oter one is . it came with with the planer
Idaho_Biker
  • 32 Answers
SOURCE: uneven thickness when planning
Surely you have some mounting screws for the Knives, don't you? You may have to loosen those and Re-set your Cutter Depth & Level. I use a "Step-Gauge" to do that with. In some Rare Cases you may have to shim to attain the desired results.
Posted on Jan 17, 2009
SOURCE: ryobie ap 1301 surface planer
I am looking fo a poly belt for a AP10 ryobi Surface planer
Posted on Nov 10, 2009
SOURCE: where can I get new
Click on the link below to order a replacement set of 12" blades for your Ryobi AH115
http://www.amazon.com/PLANER-BLADE-SET-AH115-RYOBI/dp/B000P8QN8U
Posted on Jan 10, 2011
SOURCE: How can I set the blades on my Ryobi AH-115
I made a very simple yet effective jig for setting blades on an old ryobi ah 115 planer. Do you still need help with this?
Posted on Jan 15, 2011
  • 582 Answers
SOURCE: Ryobi AP1301 planer. Suddenly
CHECK THE ROLLERS THAT PULL THE WOOD THRU, I HAD TO REPLACE MINE FOR THE SAME REASON.
IF THEY HAVE A LOT OF USE YOU WILL SEE WORN FLAT SPOTS ON THE ROLLERS CAUSING THIS PROBLEM
Posted on Jan 16, 2011
Ryobi AP1301 planer. Suddenly started getting ripples in wood.parallel to blades. Tried reversing blades to unused side, made no difference.Only trying to take of about 1/16". Stock is...
Jan 16, 2011 | Ryobi Thickness Planer Blades
Where do i find a belt for ryobi 18v planer model cpl 180
If you have the remnants of the old belt, take it to a well stocked hardware or auto parts store. If the belt is missing, you will need to measure the width of the outer 'V' on either pulley, the diameters of both pulleys, and the distance from shaft center to shaft center. The folks at the store can compute the proper belt width and length from that. Be sure to set the motor position so that there is about 3/8 to 1/2 inch deflection of the belt at mid-point and that the two pulleys are in the same vertical plane. This will greatly increase the belt life. Hope this helps!
Sep 12, 2010 | Ryobi Thickness Planer Blades
Uneaven thickness when planing. how do i adjust
You mean you're getting speed bumps? Do you have the blade setting tools that came with the planer? You need them, it will be hard to do without them. It is a little C shaped jig that rides on the drum over the knife, you have your knife sharpened and set in the drum, snug, not tight,under the knife are adj screws, you run the knife setter around the drum and just scrap the top of the knife, do not pull the knife, just go over it barely scraping it, then snug it up, do not tighten anything yet, move on to the next screw, do the same thing, then the last screw, then go back to the first, still good? second, third, now, tighten them up, the setter doesn't pull the knife, just barely scrapes it, but it does hit it. Now do the other side. Both knives will be set the same, no more speed bumps, or uneven cuts. To move the knife back in, if you brought it out too far, use a block of wood to tap it down, make sure you put the elevation screw down first. Do not answer the fone while doing this. It is serious stuff, when those knives start flying. Hope this helps.
Jul 07, 2010 | Ryobi Thickness Planer Blades
How to replace drive belt on ryobi thicknessor
How to change belt on a ap10 thickness planer
May 09, 2010 | Ryobi Thickness Planer Blades
I have a 12 5/16'' ryobi planer and need a place to get a set of knives and books.
go to home depot and purchase DELTA 12 1/2 inch blades. make sure they are centered so they don't rub the sides of the housing or grind off a little bit off each end.
Oct 18, 2009 | Ryobi Thickness Planer Blades
Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
Aug 06, 2009 | Tools & Hardware - Others
Uneven thickness when planning
Jan 10, 2009 | Ryobi Thickness Planer Blades
Ryobie ap 1301 surface planer
Here is the Ryobie support web site . You may still be able to get the manual for your service planer.
https://register.ryobitools.com/customer_session/new
Dec 22, 2008 | Ryobi Thickness Planer Blades
Masonry Tools Logo
176 people viewed this question
Top Masonry Tools Experts
ray gallant
Tom Chichester
Are you a Masonry Tool Expert? Answer questions, earn points and help others
