Question about Coffee Makers & Espresso Machines
Clean the machine - Coffee Makers & Espresso Machines
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Descale
Posted on Dec 11, 2014
Low water level
Clean the intake filter and drain pipes
Pour the vinegar into a measuring cup and head over to your washing machine.
  1. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. ...
  2. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue.
How to Clean the Inside of Washing Machine
Sep 10, 2016 | Washing Machines
Machine constantly saying "clean now" even directly after a cleaning
The machine continues to say clean now after a clean if it hasnt been competed corrected or interrupted. A cappuccino clean wil not clear the message you have to complete an entire clean the milk and the coffee brewer. an internal leak on to the drip try contacts will also give problems. If you require addition help let me now ...
Jun 26, 2014 | Jura Impressa X9 Espresso Machine
Reset clean light
Did you clean the machine? When you went through the cleaning steps it should have cleared the clean light. I will tell you what to push first Remove the front cover. If the machine is operating then push and release the harvest button. When the machine completes the Harvest cycle it will stop. Push and release the OFF button. Push and release the clean button. The yellow clean light will blink and display will show C. The machine will drain the reservoir and refill it. Go into the next step when the reservoir has filled. Allow the the ice machine to circulate water for at lest 10 minutes. Normally this is when you would add your cleaning solution but i take it you have already cleaned the machine. Now push and release the Clean button again. The yellow Clean light will be on continuously and the machine will drain and refill the reservoir repeatedly to purge out the ice machine. Now Allow the drain and refill process to continue for at least 20 minutes. Now Push and release the OFF button. The clean cycle will stop and the display will show 0. Now push and release the on button. This should have cleared the yellow clean light. Now with that out of the way if it did not clear it then you will need to replace the control board. The machine will steel make ice with no problem and you just clean the machine every 6 mounts. The yellow clean light is just to remind you that it is time to clean the system. The board is quite costly.
Apr 24, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
IT STUCK IN CLEANING MODE. AND WONT RESET. WHAT DO I NEED TO DO.
This is normal behavior for a Miele machine, it is a safety feature. You have to clean it.
Use the cleaning tabs you have that came with your machine, if you don't have anymore, get them here http://www.amazon.com/Miele-05626080-Cleaning-Tablets-Packet/dp/B001BNV3GK
Clean the machine normally by opening the machine up, removing the storage tray, and dropping the tablet down the ground coffee shoot and letting the machine lead you through the cleaning.
Hope this helps.
May 31, 2011 | Miele CVA4070 Coffee Maker
Hi my whirlpool washing machine keeps stopping with the clean pump light on. I have cleaned the filter at the front and removed the pump underneath to clean it and to make sure there was no blockage. It...
Hello
There should be a clean mode.You need to get some E A high effic cleaner.And run the machine in Deep cleaning mode.
This will clean the machine and drain.
Apr 04, 2011 | Washing Machines
How do i clean the brew head of the FFx1. It says in the instructions to put the tablet into the filter holder and run the water through but with the machine off and cold, how can this work??
The water alone will not do much for cleaning but it will rinse it between daily use.
To actually clean the machine, I use a cleaning product such as clear1x1.gifJoe Glo - Espresso Machine Backflush Detergent.
http://www.seattlecoffeegear.com/Joe-Glo-Espresso-Machine-Backflush-Detergent-p/scg10023-4.htm
The tricky part is the actual cleaning, first your going to want to clean the tank, and dump that out. Then re-fill the tank with cleaning product and run it through the machine. After cleaning run water through at least twice. If you don't do this you will just force the gunk from the tank into the head, clogging it worse.
Additionally they make a brush for scrubbing the head, if needed.
Sometimes when I don't have the detergent I just use white vinegar.
Enjoy your espresso machine.
Feb 28, 2011 | FrancisFrancis! X1 - Stainless Steel...
The "clean machine" edit will
How are you doing the clean cycle ?
You should put a tablet in the coffee grounds front lid.
Push the clean button on the inside front panel.
The machine will ask you to open tap and empty tray along the way.
Make sure it does the full cycle.
Jan 30, 2011 | Jura Capresso Impressa S9 Coffee...
How do you clean the door gasket? It has black stuff on it.
once a month bleach machine out and clean out soap and softner dispenser,so lets start cleaning you are going to need a powerful-pool shock and put 1/4 of the bag in the soap area,you well need to let it soak for 24hrs. cause you have mold in every inch of the machine.Now run the machine on cold water.After machine has gone through all cycles.Open door you may need to clean door seal with a old tooth brush,and you may need to lift seal to check underneath.after seals are clean and dispencer is cleaned were dispencer goes make sure its clean as well. after use always keep door open and dry out dispencer after each use.always use a 1/4 of a cup of clorox2 for HE. and clean machine out this should stop ths problem.
Jun 17, 2010 | GE Energy Star WCVH6260F Front Load Washer
Impressa S7 "Clean Machine"
I had this problem and I solved it by letting the machine dry out overnight. Before I turned it back on I removed the drawer and wiped the area inside the internal flap then I used the pressurized air that you use to clean a computer and blew out all of the residue. It has worked well since then.
Oct 07, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Clean machine/machine ready light won't go away
Have experienced the same problem for the last nine months. Was finally able to solve it today by following this guide: http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Having cleaned the shower screen I ran the regular cleaning cycle and now the display indiucates "Ready" as it should do.
Sep 07, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
