Question about Lifesaver Kidde 1275 120Volt9Volt BatteryElectric Smoke Alarm
I have a Lifesaver 1275 that was in the house when I bought the house. I was working in the garage with the leaf blower and set the alarms off. It's been over an hour with the door open and it
I have a Lifesaver 1275 that was in the house when I bought the house. I was working in the garage with the leaf blower and set the alarms off. It's been over an hour with the door open and it hasn't shut off by itself. What must I do?
Alarm keeps chirping even with battery is replaced?
This could mean that the unit is defective or it may need to be replaced...check the date on the back of the device; if it's over 10 years old it must be replaced by code (NFPA72).
Feb 24, 2015 | Lifesaver Kidde 1275 120Volt9Volt...
Why does my smoke detector goes off when its cold in the house
Since that model has the capability to be "chained" together with other units see if one of the others is too close to a heat or smoke source, maybe furnace or hot water heated or kitchen.
Feb 21, 2015 | Lifesaver Kidde 1275 120Volt9Volt...
How can I change battery of smoke alarm model 1275?
If this is a Kidde 1275CA alarm, then grip the outside and turn it to release from mounting bracket, then on the underside is the battery housing to be slid off to replace!
Dec 29, 2014 | Home
My Kidde Frynetics 1275 smoke alarms started going off intermittently. (Slower than when there has been smoke in the house from the oven). THere was no fire and no smoke. Not sure why?
Make sure to only use a brand name alkaline 9 volt battery. Don't use a used battery or a dollar store battery (bargain store). Then press the test button for 10 seconds to reset this unit and any more down the line.
Oct 28, 2013 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Broken pull cord mac320v leaf blower
The pull string is in a housing underneath the fan. Remove the left (as you're holding the blower with the outlet facing away) housing. The blower fan is visible. Use a 1/2" light duty impact driver, it's a conventional clocking leftie loosie rightie tightie. Remove nut, thick flat washer, fan, and another thick flat washer. Three screws are holding the pull string housing. Remove the housing. Three more screws and thin flat washers, and the spool is in your hand. Reassemble in reverse order.
Apr 15, 2013 | Homelite Consumer Products Backpack...
For a Sears Garden Blower Model # 257.796330, I need the Sears Vaccum Attachment Model 79988.
per sears's website there is no attachment for this electric blower, www3.sears.com
Nov 17, 2009 | Craftsman Garden
My black and decker leafhog blower/vac smells like something is burning
Black and Decker has issued a recall notice for Type 1 BV4000 because "a loose connection between the unit and an extension cord can create heat, posing a possible fire hazard" Says to STOP USING and call 1-866-853-2138 to arrange for free repair. (Found info by Googling "Black and Decker Leafhog", navigate to Black and Decker website and click "Important Safety Recalls" button at bottom of page.)
Nov 08, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Power Source Problem
# Electric leaf blowers are lighter, quieter and vibrate less than gas units. An electric motor drives the fan, so there's no need to mix fuel or refill. Smaller yards are especially good candidates for electric blowers. There are two types: * Corded leaf blowers provide constant power as long as you have access to an electrical outlet. The attached cord limits mobility so this may not be the best choice for a lawn with lots of trees. Look for a cord retention system to prevent the cord from being accidentally unplugged during use. * Rechargeable/battery-operated leaf blowers are good alternatives for smaller areas or jobs. They work well on solid surfaces like driveways and garages. They're limited by their run time and the fact that they move less air than larger models. # Gas-powered leaf blowers use a 2-cycle engine, requiring mixing oil and gasoline. Mobility and work output are increased with gas blowers. They're louder and heavier than electric blowers.
Aug 27, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Lifesaver Kidde 1275 120Volt9Volt BatteryElectric Smoke Alarm Logo
42 people viewed this question
Top Lifesaver Home Security Experts
Lawrence Oravetz
Are you a Lifesaver Home Security Expert? Answer questions, earn points and help others
