Question about General International 15-220M1 Oscillating Spindle Sander
<!-- from fixya rte -->How do I get the abrasive sleeve off and on? - General International 15-220M1 Oscillating Spindle Sander
    Problem Solver:
  • 8 Answers
At the end of the drum ,there will be a screw or nut . Loosen it , and you should be able to winkle the sanding band off. If not , tear it off carefully , then clean the drum with rubbing alcohol and a brush ( not a steel one )
Posted on Nov 30, 2014
How do I replace headlight dimmer switch on a 2003 chev impala do I have to pull the steering wheel
Yes , the steering needs to be pull .
Disable the SIR system. Refer to SIR Disabling and Enabling in SIR. Remove the steering wheel. Refer to Steering Wheel Replacement . Remove the upper and lower trim covers. Refer to Steering Column Trim Covers Replacement .
Important: The abrasion sleeve located on the steering column wire harness assembly must be reinstalled. Make note of what connector is coming out of the abrasion sleeve for installation purposes.
Remove the wire harness assembly (1) from the wire harness strap (2). Disconnect the turn signal and multifunction switch assembly connector from the SIR system coil connector.
There could be a video on youtube show how to do it .
Theret
Oct 20, 2016 | Cars & Trucks
Why has my dremel 6000 just stopped working could it be the brushes
Although Supergrit Abrasives in Gettysburg, PA sells the sleeves and the Hook & Loop diamonds for use with the Dremel 6000, we do not repair tools. The 6000 is discontinued, but you can probably buy a used one that works on Ebay.
Jun 14, 2014 | Dremel 6000 Contour Sander
Brake light stays on all the time throttle side signals not working
Sounds like you may have a wiring problem in the right handlebar switch assembly. The front brake light switch is in that housing as well. It could be a problem with the wire bundle running to the main wiring harness from that right side as well. Check for abrasions on the wires.
If you go into the handlebar switch housing, loosen the throttle cables up so you can remove the throttle sleeve. This will enable you to have greater access to the switches. If you have ot replace the switches, the wires usually have to be resoldered.
Good Luck
Steve
Aug 30, 2010 | Harley Davidson FLHR-FLHRI Road king...
Recomended cleaning for kitchen porcelain sink
Scouring powders or cleansers contain abrasives commonly used to clean and remove stubborn stains that are slow to respond to chemical action alone.
However, use of an abrasive cleaner may scratch and damage smooth finishes such as porcelain, fiberglass or enamel making it even more difficult to clean the surface in the future.
New kitchen and bathroom fixtures do not require a scouring cleanser to clean them of soap films and body oils. Dissolving soil by soaking with the correct non-abrasive cleaner (especially a foaming type that sticks to the surface) then wiping and rinsing usually does the job.
When cleaning older, abused fixtures, choose the mildest abrasive cleaner available such as a Soft Scrub -type product or baking soda, and apply just enough that, with light pressure, the embedded soils are loosened and may be rinsed away.
Aug 21, 2010 | International Thermocast Corp Thermocast...
Cleaning black cooktop surface - what products to use.
It is recommended that you use a straight edge razor blade and push in one direction to remove anything stuck to the surface of a glass cook top. Stubborn, cooked on, substances can be cleaned by scrubbing with a light abrasive cook top cleaner and/or a green kitchen scrub pad. The green srub pads are considered non-abrasive and safe for cook tops. You can also use liquid dish detergent (such as Dawn) to break through grease and grime. DO NOT use steel wool, SOS pads, or any scouring powders. These products can permanently scratch or dull the finish on your cook top. If you have any questions please let me know. I hope you find this information helpful.
Apr 27, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
I need to install my cruise control switch on my steering wheel . How do I go about removing the back cover on the steering wheel?
Removal & Installataion
  1. Verify that the multifunction turn signal lever is in the center of the OFF position.
  2. Disconnect the negative battery cable.
  3. Disable the SIR (air bag) system. Refer to the Chassis Electrical Section.
  4. Remove the air bag module from the steering wheel.
  5. Remove the steering wheel.
Exploded view of the shroud-type steering column showing shrouds, wiring and multifunction switch that includes the headlamp function
    1. Remove the upper and lower steering wheel trim covers using the following procedure.
    2. Remove the tilt lever assembly.
    • Remove the two pan head tapping screws from the lower shroud.
    • Unlock the upper and lower shroud.
    • Remove the two Torx® head screws from the upper shroud.
    • Remove the upper shroud.
    1. Remove the wire harness straps from the wire harness assembly and detach the wiring harness connectors from the switch side connectors.
    2. Remove the two multifunction turn signal switch screws and remove the multifunction switch assembly from the vehicle.
    To install:
    1. Install the multifunction switch to the steering column. Use a small flat-blade prytool to compress the electrical contact and move the multifunction turn signal switch into position. Verify that the electrical contact rests on the canceling cam. Install the screws and tighten to 62 inch lbs. (7 Nm).
    2. Route the wire harness along the steering column jacket assembly and secure into the wire harness strap. Install a new wire tie to the upper tilt head assembly and another lower along the wiring harness, as the original installation.
    3. Verify that the lever is in the center of the OFF position.
    4. Install the upper and lower steering column shrouds.
    5. Route the SIR connector through the steering wheel, align the scribe mark on the steering wheel made at removal, with the slash mark on the steering shaft and install the steering wheel. Install the steering shaft nut and torque to 30 ft. lbs. (41 Nm).
    6. Install the horn contact leads and the air bag connector to the back of the air bag. Make sure the CPA wedge is in place to secure the connector. Install the air bag by gently pushing on both the right and left sides of the air bag until the retaining springs engage.
    7. Enable the SIR system by connecting the yellow 2-way connector at the base of the steering column and installing the air bag fuse.
    8. Connect the negative battery cable. Test the horn, turn signals and headlight operation.
    1. Disable the SIR system.
    2. Remove the upper and lower trim covers.
    3. Remove the knee bolster.
      NOTE The abrasion sleeve located on the steering column wire harness assembly must be reinstalled. Make note of what connector is coming out of the abrasion sleeve for installation purposes.
    4. Remove the wire harness assembly from the wire harness strap.
    5. Disconnect the turn signal and multifunction switch assembly connector from the SIR system coil connector.
    6. Slide the 2 connectors of the turn signal and multifunction switch assembly out of the bulkhead connector.
    7. Remove the 2 pan head tapping screws and from the turn signal and multifunction switch assembly.
    8. Remove the turn signal and multifunction switch assembly from the steering column tilt head assembly.
    To install:
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
    CAUTION Be sure that the electrical contact of the turn signal and multifunction switch assembly (2) rests on the turn signal cancel cam assembly.
    CAUTION The abrasion sleeve must be installed back onto the steering column wire harness assembly. The ignition lock cylinder case wires and connector must be hanging out of the middle of the abrasion sleeve.
    1. To install, reverse removal procedure.
    2. Tighten the following to specification.
      • Top pan head tapping screw: 27 inch lbs. (3 Nm).
      • Side pan head tapping screw: 62 inch lbs. (7 Nm).
    CAUTION When performing service on or near the SIR components or the SIR wiring, the SIR system must be disabled. Refer to SIR Disabling and Enabling . Failure to observe the correct procedure could cause deployment of the SIR components, personal injury, or unnecessary SIR system repairs.
    Dec 08, 2009 | 2005 Chevrolet Impala
    What wheel do I use for grinding chrome
    Grinding chrome is not recomended on a bench grinder
    Aug 30, 2009 | Baldor Grinders
    I have a 73 vw bug stock 1600. with a oil leak on the crankshaft. i change the pulley, with one that has a seal.but it works for a day,then it bows oil all over. Could it be the oil pressure valve is maybe...
    check crank shaft for damage, check PCV valve for proper operation, check that pulley sleeve is smooth with no abrasive areas that would chew up a seal, if needed try a speedy sleeve repair kit...
    Aug 12, 2009 | 2007 Volkswagen Beetle
    Limitation for use of abrasive grinding wheel
    All abrasives are marked with a maximum speed rating. Always check the rated speed of the tool you are mountin the abrasive on and be sure the rated speed on the wheel is equal to or higher than the rated speed of the tool. Never remove a guard to mount a larger wheel on a grinder than it is rated, even if the speed rating is ok!
    Mar 15, 2009 | Saws
    General International 15-220M1 Oscillating Spindle Sander Logo
    47 people viewed this question
    Top General International Tools & Hardware - Others Experts
    J.D. Browning
    J.D. Browning
    Are you a General International Tool and Hardware - Other Expert? Answer questions, earn points and help others
