Question about Sanyo Televison & Video
<!-- from fixya rte -->Does it have ahead phone point - Sanyo Televison & Video
    Top Expert:
  • Sanyo Master
  • 75,178 Answers
No. It hasn't. Electro help
Posted on Nov 14, 2014
Power steering jumping off straight ahead position
Make sure the power steering fluid level is at the appropriate level.
Also, if you haven't changed the fluid according to the manual, it may be time. Let the mechanic know your observation before changing the fluid.
Apr 11, 2016 | Cars & Trucks
Phone number for lincoln trading standards
I would just go ahead and call up lincoln motor company's customer service at 1-800-521-4140. I'm sure they could point you in the right direction.
Feb 20, 2015 | Lincoln Cars & Trucks
Every time the phone rings and is in use I loose my wireless connection This never happened with my old 2wire how do i fix this
Make sure you have a filter installed ahead of all things that plug into your phone line except your dsl modem.
Feb 27, 2011 | Computers & Internet
On a Sidekick Blade LX 2009,when I try to turn it on all I get is a white screen with a small black square and white circle dots that look like the jump button. How do I get it to turn on?
Try removing the battery if possible. At that point, go ahead, reinsert the battery and try to power it on. If that still does not work, you may need to contact the technical support for your phone (your cellphone carrier)
Sep 25, 2010 | Cell Phones
Audio driver
Go to this page.
This page is for your laptop. Choose your operating system and then on the next page go ahead and choose the audio - driver link.
After that go ahead and download the driver to your desktop. Then go ahead after the download and run it. This will install the audio drivers for you and you should have sound at this point.
Sep 22, 2010 | HP 6730b Intel Centrino 2 Core 2 Duo T9400...
Am tgrying To shut off the answering unit on the power Head.
There is a button on the base unit labeled answer on. Right next to is a light that indicates whether the answerer is on.
If what you are trying to do is stop the playback of messages, press the stop button. It has a square. If you want to resume playback, press the play button. It has a right pointing triangle. There are other buttons and they are also labeled like on a standard recording device for if you want to skip ahead orback.
Aug 11, 2010 | Panasonic KX-TG1033S Cordless Phone
My samsung propel was working fine. I was sending a message and I watched the screen fade out and now it stays bright white. I can play music, make and receive calls and it still receives messages. I...
Yikes, sounds like LCD problems for sure. If you haven't already go ahead and turn off the phone and take the battery out for a good two minutes. After that go ahead and put it back in and turn it on. If the problem is still there then the LCD has actually failed out, this happens eventually but is very uncommon for it only being 7 months old. What you will want to do at that point (and maybe regardless since this problem may come back even if the battery pulling out fixes it) is call your service provider (Verizon / AT&T, whoever) and tell them of the problem. The phone has a 1 year warranty and this is definitely covered. They will replace the phone for you for free.
Hope this helps!
Tim
Jul 27, 2009 | Cell Phones
Screen swap out for a sony vaio vgn-fw235j
With the power disconnected. First off there are 4 rubbers on the screen bezel itself. Take those off and then unscrew the 4 screws.
Then take off the screen bezel itself, it will be held in by clips so you may have to use a flathead to pry it off.
Once you expose the screen, there might be one screw on each side holding in each screen hinge, if so that those screws out.
At this point there will be 4 screws holding the screen in on both the left and right side hinge.
Go ahead and take off the 4 screws on each side of the hinge and this will loosen the screen completely.
At this point go ahead and unseat the connector that goes to the inverter toward the bottom of the screen. Also unseat the connector that goes to the back of the lcd.
At this point you will have the old screen removed.
Now go ahead and screw in the screws on the left hinge and right hinge so the new screen will stay in place. Go ahead and hook up the connector to the inverter, hook up the connector to the back of the lcd. At this point go ahead and turn on the laptop and just verify that the screen works and that there is no defects such as lines in the screen or weird colors. If there is then you'll need another screen.
If you have the 2 screws, screw each one on each side of the hinges to keep the hinges in place.
Then go ahead and snap the front bezel in place, then go ahead and put the 4 screws in place and then the rubbers on and you'll have a working laptop with a new screen in place.
Mar 11, 2009 | Sony VAIO VGN-FZ230 FZ Series Notebook
Water damage
Water damaged phones do not get repaired. The electronics are way to sensitive. I recommend you go ahead and shop for the new phone.
CH
Jul 30, 2008 | Samsung SCH-u540 Cellular Phone
Dropped my camera from about 36" on a linoleum floor
hi , let professional camera repairman fix you camera , fixya has recommended repair shop near you just enter you enter zip location number .
Nov 27, 2007 | Canon PowerShot A620 Digital Camera
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
