Question about Black & Decker ICR200 Iron with Auto Shut-off
How do i remove a black smear on my sole plate icr 500
    Master:
  • Black & Decker Master
  • 996 Answers
Clean it with a sharp edged blade slightly ,only when it is hot
Posted on Jan 21, 2015
How do IO remove the sole plate because a screw has come loose inside at the front making the sole loose
you have to access the iron from the top or from the heal. the base is solid and can not be accessed from the bottom look on the heal plate of screws then the top should lift foward.
I hope this was useful
May 01, 2014 | Russell Hobbs 15129 Slipstream Iron
Cannot get black stains off with the cleaner kit from Rowenta that I bough at Bed Bath and Beyond. Used almost all of the cream and still not clean. adjina39@aol.com
Are you heating up the soleplate first to get it really hot, then put on an oven mitt to protect your hand, squirt cream onto a folded pad of clean cotton fabric, then apply to iron sole plate, rub over stained area gently, wait, then rub off. you may want to rub the whole iron sole onto a piece of waste fabric to remove the burnt bits. Itcan take a couple of goes to clean. The ironing press cleaning sticks work well too.
Nov 03, 2013 | Rowenta Irons
How do you run clean cycle - I have lost the manual
Self-Cleaning and Maintaining Sole Plate
Use the self-cleaning feature once a month by moving the steam lever back and forth from the "dry" setting several times. This will remove any residue from the steam valve and ensure that the steam system works properly.
Wipe the sole plate with a soft, damp cloth while the iron is cool and unplugged.
Run the iron over a cotton cloth several times to remove any residue from the sole plate.
Cleaning Anti-Calcium Feature
Fill the water cup that came with your iron. Use enough water to reach the Sunbeam logo in the top corner of the cup.
Add a teaspoon of salt to the cup and stir.
Empty the salt solution into the water reservoir in your iron.
Allow the iron to stand for 15 minutes, then empty out the water reservoir.Repeat this cycle with a second cupful of salt water.
Rinse out the reservoir with clean water. You should perform this cleaning once a month.
Jul 28, 2011 | Sunbeam Irons
I have a morphy richards turbo steam iron i have had it for some 2 weeks and used it 6 times and fill it with normal tap water. on using it tonight i have noticed that there are white smears been left on...
The white stain is due to mineral build up on your iron.
Try flushing the iron with a vinegar solution to dissolve the mineral deposits then purge with demineralized water. Only use demeralized water in your iron. The first time you may want to test it on a scrap piece of cloth to insure all of the minerals have been removed.
Jan 04, 2011 | Morphy Richards Irons
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Sticky black mark under my tefal iron
yes i did fix the probleme thank you. I did not that if i use you it would cost money.
Oct 06, 2009 | Micro Pro 7599 Iron
I can't seem to open up my ICR-250 B&D iron
Sometimes you can gently pry it open if you can't see any more screws.
Jun 30, 2009 | Black & Decker ICR200 Iron with Auto...
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Black & Decker ICR200 Iron with Auto Shut-off Logo
77 people viewed this question
Top Black & Decker Irons Experts
nmccully
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
