Why won't my akai tower speaker work
It won't switch on, everything tried, new today. switched on first go, now wont switch on
    Master:
  • 409 Answers
Have you checked that the Speakers are not 'muted' in the Operating System ? Or that the volume is turned-down low ?
Posted on Nov 15, 2014
4 Suggested Answers
  • 7 Answers
SOURCE: will not boot
try different ram....even though the specs say it should work and you have good ram it is possible the motherboard and the ram are not compatible. try some kingston or pny ram...if that doesn't work send mother board back...you may have a bad processor...even though new parts doesn't mean they are good.
Posted on Apr 26, 2009
  • 1019 Answers
SOURCE: i have a dell C521 tower,switch it on but light
if the light remains Orange, Possible In Standby/Sleep/Hibernate Mode.
Try pressing And Holding The power Button For 4-5 seconds Or more.
If this Fails, remove the power Cable, remove side-panel ( Unless Warranted ) locate the silver cmos battery, on the motherboard. remove the battery for 10 seconds, replace and repower and startup. failing this i,d suspect the ram/memory or cpu.
Mike @ Compurepair.
Posted on Oct 30, 2009
SOURCE: how to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
Posted on May 02, 2012
Switch on akai58022 tower speaker, it worked when I got it today and now it wont even switch on
what do you have it plugged-into for power ? it uses the 8-pin Apple Lightning dock connector. If you are using a USB adapter for that, then be aware that a USB-port will only let you draw 500mA or 1/2 an Amp of power....more than that will cause failures and damage to the USB port and the Hub even.
Nov 13, 2014 | Audio Players & Recorders
Dell optiplex mini tower wont turn on
Make sure the power is being supplied from a working source, then check if the switch on the bottom-back of the computer is switched on. If the power button still doesn't work, try holding the button down for 10 seconds. Next, try switching the switch off, unplugging the computer for at least 30 seconds, plugging it back in, switching the switch back on, and pressing the button.
Apr 25, 2014 | Dell Studio Mini-Tower Desktop Computer
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
JBLPro Compac computer speakers wont work
Well from what you said no device, it was not detected because of your new magic jack. There might be a conflict in your hardware. Try scan plug and play devices if it can detect your jbl or reinstall both you devices.
Nov 30, 2009 | Computers & Internet
20 minutes ago my computer was fine, its a packard bell imedia 3051. i turned it off the usual and proper way and switched it off at the wall. i just switched it all back on and now it wont even turn on i...
I am giving you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to unplug the power cord from the tower and also remove any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers mouse, keyboard).
Nothing should be connected at all to the tower.
Now Press and hold the power button on the tower for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the Power, keyboard and mouse and check, it should certainly work now.
Hope this should help
Regards
Sammy
Aug 28, 2008 | Packard Bell Computers & Internet
Compaq presario sr1115cl wont power up
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Jul 01, 2008 | HP Compaq Presario SR1420nx...
Akai LCD TV wont turn on
Hello davidshu,
The issue seems to be a power supply problem. The television has a switching power supply. This might be the problem. I would suggest getting it repaired at a television repair shop due to the possible complexity of the work that needs to be done.
Apr 16, 2008 | Akai LCT3201AD 32 in. LCD Television
TV Akai CT29X4AV
Have tried checking if the Power Plug is fitting tightly in the Power socket? Could be that it is loose?
May 27, 2007 | Akai CTS2550 25" TV
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
