Switch on akai58022 tower speaker, it worked when I got it today and now it wont even switch on
I wont switch on, brand new today, everything we can think of tried
    Master:
  • 409 Answers
What do you have it plugged-into for power ? it uses the 8-pin Apple Lightning dock connector. If you are using a USB adapter for that, then be aware that a USB-port will only let you draw 500mA or 1/2 an Amp of power....more than that will cause failures and damage to the USB port and the Hub even.
Posted on Nov 15, 2014
2 Suggested Answers
SOURCE: how to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
Posted on May 02, 2012
Why won't my akai tower speaker work
Have you checked that the Speakers are not 'muted' in the Operating System ? Or that the volume is turned-down low ?
Nov 13, 2014 | Computers & Internet
LG Flatron E2042. Brand new. New CPU. Windows 7. I plugged in my new monitor today. Does not turn on automatically. But when I do turn it on I get an error message. D SUB POWER SAVING MODE and tur
Your new moniter may not be compatible with your computer. I have an Emachines that won't take a flat screen. I have to use a big bulky moniter because it says not connected even thought the hookup fits the back of the tower. That might be your problem. Did your old moniter work correctly?
Nov 15, 2012 | Computers & Internet
How to double check speaker hook up on asus desktop computer
May 02, 2012 | ASUS Computers & Internet
The rear channel has suddenly gone silent and all settings appear to be proper. Not even the test tone works. Wiring is fine and speaker is fine because I switched speakers and only the one plugged into...
Hi, the test tone should be the definitive test of all channels. Yes it is a little rare for the rear channels to go out. My advice is to buy a new receiver. They have gone down in price considerably over the past few years. I would think to repair it it will be at least a hundred dollars-versus a brand new one for nearly the same price. So long story short, I don't think you can disable the test tone feature with any button on the remote. Be sure to ask your local repair shop to give you a " ballpark " estimate on the repair cost if they can to aid you in your decision making. I hope this was helpful, please comment back to us and let me know, good luck-Prodzilla.
Apr 24, 2011 | Denon Audio Players & Recorders
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
Tower is properly connected but I have difficulty with the switch
even if its brand new... there's still a possibility that your power switch is defected... you may try to change the power cord or try to go to the service center to replace your unit or repair if it has a warranty.
Jan 09, 2010 | Sony VAIO VGC-RB42G PC Desktop
20 minutes ago my computer was fine, its a packard bell imedia 3051. i turned it off the usual and proper way and switched it off at the wall. i just switched it all back on and now it wont even turn on i...
I am giving you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to unplug the power cord from the tower and also remove any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers mouse, keyboard).
Nothing should be connected at all to the tower.
Now Press and hold the power button on the tower for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the Power, keyboard and mouse and check, it should certainly work now.
Hope this should help
Regards
Sammy
Aug 28, 2008 | Packard Bell Computers & Internet
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
Subwoofer not working
Hi, What speakers (+sub) are you using (brand/model)? You have to consider whether it is basic 2, or 5.1 or 7.1. the Dell Dimension 9200C uses multiple sound connector at the back, the center/LFE connector (orange) should go to the sub-woofer in a 5.1 or 7.1 speaker system. An online manual is available @ http://support.dell.com/support/edocs/systems/dim9200C/en/SM_EN/about.htm Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Aug 27, 2007 | Audio Players & Recorders
59 people viewed this question
 Grubhead
Grubhead
