Question about Boost Mobile LG Realm No-Contract Cell Phone
I have an LG realm and as soon as i turned on the talkback feature the screen became unresponsive only to scrolling up and down, i dont want to have to reset it and i already did powercycled it, Thank
Troubleshooting steps needed. as soon as i turned on the talkback feature the screen became unresponsive only to scrolling up and down, i dont want to have to reset it and i already did powercycled it
I cannot disable talkback on my Samsung gear S2. I an not get into my phone or any other app on my watch
You have to goto settings from the home screen and using two fingers you can scroll down to "accessibility" double tap it to open it, scroll down to "talk back" double tap it and double tap the toggle off.
May 06, 2017 | Samsung Cell Phones
How do i turn off talkback mode and reboot the phone to factory settings
You can try the below if you are having Samsung Galaxy phone.
  1. Double-tap on the Settings icon to get to Settings.
  2. Scroll down to "Accessibility" using your two fingers.
  3. Double tap on the switch to turn it off. Talkback is now disabled on your Samsung Galaxy Core
And to reset to factory setting, follow the below steps.
To do a factory data reset, follow these steps:
  1. If your phone is on, turn it off.
  2. Press and hold the Volume up button and the Power button at the same time until the device turns on.
  3. Press the Volume down button to select "Recovery mode." If you need to navigate to the "Recovery mode" option, use the Volume up button to move the arrow and the Volume down button to select it.
  4. You'll see an image of an Android robot with a red exclamation mark and the words "No command."
  5. While holding down the Power button, press the Volume up button and release it.
  6. Use the volume buttons to scroll to "wipe data/factory reset" and press the Power button to select it.
  7. Scroll down to "Yes - erase all user data" and press the Power button to select it.
Your Android One device will erase all of your data and restart with its factory settings. You'll see the Welcome screen just as you did when you turned the device on for the first time.
May 16, 2016 | Cameras
I have voice to tell me what everything is but can't get to the setup
Looks like you've accidently enable the Talkback function on the phone. You'll need to turn it off to be able to use the phone normally.
Note: To select anything tap it twice, to scroll use your thumb and index finger like you are pinching on the screen.
To turn off talkback, you'll need to get to the settings on the phone. Under settings look for Accessibilty, click on the Talkback and turn it OFF.
Apr 25, 2016 | Cell Phones
How do I turn off the talk back feature on lg tribute
TalkBack won't turn off - Google Product Forums
productforums.google.com/d/topic/nexus/av7djMHBA14
Google
Oct 23, 2013 - 100+ posts - ‎100+ authors
Re: TalkBack won't turn off, Nexus 5 -curious user, 2/15/14 6:38 AM ... I don't blame Google for making this feature so difficult to shut off once ...
How to Disable Talk Back Mode? « Android Gadget Hacks
android.wonderhowto.com/forum/disable-talk-back-mode-0147617/
Jun 24, 2013 - If you just have the regular swipe to unlock feature for your lock screen, to unlock it ... Now, to disable TalkBack mode, you need to make your way to ... I only turned on because my lady friend has an LG Stylo G and she set her ...
How to Exit 0r Disable "TalkBack" Mode on LG Optimus F6 ...
? 3:11
https://www.youtube.com/watch?v=YDmcLi9kF8w
Dec 3, 2014 - Uploaded by Klavdio-Leadership
This Video will show you how to disable the TalkBack Mode on your phone.
LG L70 how to Turn off the talkback or voice over - YouTube
? 2:29
https://www.youtube.com/watch?v=FEei11i4OGg
Jan 13, 2016 | LG Tribute 4G No-Contract Cell Phone
HOW TO UNLOCK SCREEN
To Disable TalkBack mode
  1. 1 Go to the home screen of your Samsung Galaxy S3 S4 or Note2. Was this step helpful? Yes ' No ' I need help
  2. 2 Now, go to settings, menu option. There is an invisible button to the left of your home button. Press that button, and select Settings. While in TalkBack mode you will have to double tap to select menu items. So double tap settings. Was this step helpful? Yes ' No ' I need help
  3. 3 Now select accessibility. Share this Share this on FacebookTweetPlusPinShareRedditDigg settings-accesibility.png While in TalkBack mode you have to use two fingers to scroll / swipe to get down to the accessibility menu item. Again, you will need to double tap to select accessibility because you are in TalkBack mode. Was this step helpful? Yes ' No ' I need help
  4. 4 In accessibility you can now disable TalkBack mode. Share this Share this on FacebookTweetPlusPinShareRedditDigg accesibility_-_talkback.png There is also an option here to disable "Text To Speech," which you must also disable. You can disable it here or an alternate method is covered in the next section. You can use either method. If you have trouble with one method, try the other.
May 23, 2014 | Samsung SGH Cell Phones
Touch screen unresponsive
Have you tried re-loading the firmware?
See this page for your tablet. Support Firmware
Feb 12, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Screen frozen
You may want to follow the step-by-step instructions posted below to hard reset you LG Nexus 4 when it becomes unresponsive. Please note that the phone will wipe all contents.
How to perform a hard reset when my LG Nexus 4 is unresponsive
1. Ensure the phone is off.
2. Press and hold the Volume down button and thePower button.
3. Scroll to Recovery mode by pressing theVolume down button.
4. Press the Power button.
5. Press and hold the Power button and then press the Volume down button.
6. Scroll to Wipe data/factory reset using theVolume down button.
7. Press the Power button.
8. Scroll to Yes -- delete all user data by pressing the Volume down button.
9. Press the Power button.
10. The phone will now wipe all contents.
11. Press the Power button.
12. The phone will now reboot to the initial setup screen.
Jan 20, 2014 | LG Nexus 4
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
My Creative Zen is unresponsive
I found the reset hole, it's okay. XD
Aug 05, 2008 | Audio Players & Recorders
Boost Mobile LG Realm No-Contract Cell Phone Logo
Top Boost Mobile Cell Phones Experts
Lawrence Oravetz
John mullen
Are you a Boost Mobile Cell Phone Expert? Answer questions, earn points and help others
