My propane heater shuts down when I switch it from low to medium.
    Novelist:
  • 166 Answers
Bunch of things here could be possible --- high limit switch/cut out---gas pressure----valve/switch
Posted on Nov 14, 2014
hiltonjug
  • 612 Answers
SOURCE: I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Posted on Oct 17, 2009
  • 53 Answers
SOURCE: propane heater shut down for summer is there a
the 'on' button
Posted on Nov 07, 2009
  • 2464 Answers
SOURCE: propane heater burning eyes
HI it sounds like you have incomplete combustion on this heater making funes needs to be checked over by a gas fitter
Posted on Jan 22, 2010
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
  • 37 Answers
SOURCE: my heater and its new, will run 5 to 10 minutes,
it sounds like a bad thermal coupling to me and the propane freeze up is normal propane is natuarly cold.
Posted on Jan 21, 2011
Does a hayward gas heater have filters within the unit?
there are no filters in these units. there is a thermostat, low limit switches, high limit switches, pressure switch (1-5lbs), fireman switch etc. because it is a propane unit, fires and runs, i would suggest checking the supply pressure for the propane. if there is less than 30lbs in the tank, the system may not run properly. if it was plumbed with the wrong size supply pipe, that could be an issue.
Jul 21, 2014 | Hayward H Series Pool & Spa Heater 200k...
Heater wire fire up but will not stay running
that code signifies an ignition failure. as your system is propane, ensure that the pressure from tank is over 30psi. under that, the system may not run properly. check to be sure that all the shut off valves are in the right position. get a technician to bleed the lines. if the heater hasnt been run for a while, it is common for the LP to not flow properly. if the outside temperature is low, this will also affect how the propane works
Jun 20, 2014 | Hayward H Series Pool & Spa Heater 400k...
Heater shuts off
medium switch or its connecting wire is faulty,should be repair by an expert
Feb 16, 2014 | Mr. Heater Big Buddy Heater
Air Flo Switch on
see if hose clogged or hole or collapsed
Jul 14, 2013 | Jandy LAARS LX250 - PROPANE, DIGITAL...
I have a propane heater that sits on the tank and has the ceramic plates for dissipating the heat. Instead of a nice blue flame, it has a lot of orange flame. Why?
I would shut off valve to heater and remove it from propane bottle. Carefully clean with soft bristle brush and blow out with medium pressure air. Reinstall and light heater and see if flame quality has improved. Often dirt,dust,and lint can build up in burner and cause fuel to not get good enough air to fully combust. Hope this helps you.Thanks
Nov 12, 2010 | Mr. Heater F191824
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Limit cycle error 4 blinks. if i shut the power off then back on it seems to run fine. it will cycle 4 or 5 times then shut down. ( even when not up to temp. the only way to get it going again is to turn...
If the fan speed is not set correctly and running on low or medium for heat then the high limit could be tripping fan should be running in high speed for heat.
Dec 11, 2009 | Coleman Propane Forced Air Heater...
Shuts off when switched to low and smells when running.
clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Nov 20, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Empire corcho ventless propane wall heater 15000 btu
LOL.... your fuel is not boiling.... the closer propane gets to its vaporization point (-44%F) the less vapor it produces. clean the snow off of the 100# or lay it on its side to give it more surface area for vaporization.
David Lawrence the propane dude
Oct 04, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
