Question about Dryers
I need to know where the plug in is for the 115 volt outlet. To run off of electricity. I have a 31ft 1977 dodge titan
    Genius:
  • Dryers Master
  • 1,848 Answers
-115 and 120 are compatible. You can use 120 outlet.
Good Luck
mai
Posted on Nov 14, 2014
2 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: a dryer that runs on 260 volts. what does the
if its wired the same as a 240 volt dryer go ahead and use it, most motor mfgrs allow a (10 percent + or -) on motors so you will just be in the ballpark, the only thing that you might encounter would be the electronics voltage difference,but i dont thing it will bother
Posted on Oct 05, 2009
I'm trying to find an ignition wiring diagram for my 1977 dodge melmar fargo f40 rv
The ignition circuit should be the same as any 1977 Dodge truck, which is basically battery to ignition switch, start side of switch bypasses ballast resistor and goes directly to coil, run side of switch goes to ballast resistor (on firewall) and then to coil. This is done so that you have full 12 volts to coil when starting thus giving higher voltage to plugs to start, but lower amps, but when running you go through the resistor to get lower volts (about 7) to coil to increase amps for a fatter spark and better fuel economy.
Dec 29, 2014 | Cars & Trucks
My incoming voltage is only reading 200v, will this stop the unit from running??
If it needs 208 or 220 then yes it will stop the unit from running.Check the voltage at the circut breaker to verify its not a wiring issue.
You may need to get a new circut breaker.Also check a 115 volt outlet if its is also reading low ,like 100 or 105 volts then the power ccompany is cutting power back and theres nothing you can do.
Jul 20, 2011 | Dayton (3UG73) Electric Utility Heater
Need help wiring unit ,sensors wall control etc. I have limited wiring exp would appreciate help
Is this a gas or electric range? Gas uses 115 Volts & Electric uses 220 Volts.
So, You will have to add a 220V wall outlet for electric stove. This is not an easy job....it really requires an experienced electrician.
If a gas range then you just plug in the power cord...nothing to wire.
Jun 26, 2011 | Kitchen Ranges
Will it run on house hold 240 volts
This machine will run on 115 or 230 volt standard house elctricity. There is a selector switch on the rear of the machine and you may have to change the plug on the power cord to suit your power outlet.
Feb 09, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
The 115 volt plug does not work what could be the problem and solution
There is a fuse for this outlet in the fuse box in the engine compartment. Look for a blown fuse and replace it with a fuse of the same rating.
Hope this helps!
Sep 06, 2010 | 2008 Dodge Grand Caravan
T V Cycles off and on as long as plugged into power outlet.
Your problem is the AC outlet, you must have an electrical problem. Call an electrician and ask him or her to run a voltage check or if you are able to, get yourself a multimeter turn the dial to AC voltage and place the red and black prongs into the outlet and see if you are getting a steady flow of voltage it should range anywhere from 110-115/120 volts AC.
Jun 28, 2010 | Televison & Video
POWER SUPPLY PROBLOMS!!!!!!!!
Unless your household electrical service is running at 230 volts, there's absolutely no reason to set your supply for 230. When you choose the 230v setting the supply REQUIRES 230 volts to become operational...Which is not going to happen on a 115 volt service.
Oct 20, 2009 | Compaq Computers & Internet
GE ASM10AK 10,200 BTU Room Air Conditioner is 115 volt, but it blows the circuit regularly becasue it has many other devices on it (IE computer, PS3, WII, LCD TV etc.). I have a 220 outlet on a separate...
It would be easier to change the 220 circuit in your house to a 110 by some creative work in the breaker panel and making it an air condtioner circuit only. You would need to check with an electrician, but would probably be worth it in the long run.
Mar 29, 2009 | Heating & Cooling
I just bought a 1977 Dodge Monaco Motorhome and just replaced the house battery with a brand new marine battery. Now I'm finding that it runs all the lights and everything except the 110 outlets. I need to...
It is called an inverter, and it may not be hooked up, u will have to trace the source power for the outlets and at the source add an inverter to change 12 volts DC to 110 volts AC.
Dec 13, 2008 | Dodge Pickup Cars & Trucks
Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
Jan 23, 2008 | Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
