Question about Saws
Need parts old saw lost arbure screw andblade collers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Would need to kno what make/mdl of saw
Posted on Dec 08, 2014
Testimonial: "ridgid 10 in mitre saw ms1050 0"
How do I change the blade on model #17224 saber saw?
Are you talking about a reciprocating saw? What brand? If this is what you're referring to, then there is usually an Allen style set screw at the base of the blade. Loosen the set screw with an Allen wrench, and replace the blade. Retighten the set screw and cut away.
Oct 06, 2014 | Saws
How to change gasket on oil cooler 2001 Kia Sportage?
An "O" ring can be purchased at your local auto parts along with your oil filter. Your oil filter screws on top of your oil cooler. Mine leaked as well. A new "O" ring and filter screwed on tightly solved my problem.
Jun 22, 2014 | 2001 Kia Sportage
The model number is Milwaukee 26 30?20 it needs a new switch it up
Lay the saw on its side with the screw in the handle facing up and battery removed... remove screw along the two half's of the saw.... you will see a seam where the left and right side meet... once screws are removed ( make sure you remember what screw goes where, there may be different sizes) lightly pry apart incase you missed a hidden screw, I'd so remove it... disconnect old broken switch and install new one... may have to order the part in
Dec 23, 2013 | Saws
Chain saw brake on husquvarna model 41
To replace the brake band do as follows, remove the bar nuts and take the brake away from the saw, engae the brake to remove as much tention off the internall spring by pushing the hand guard fully forward, remove the allen screw securing the hand guard, do not remove the e clip and pin from the hand guard, tap out the pivot collers and remove the hand guard, remove the cross head screws securing the spring cover, carefully remove the spring from under neath, tap out the silver pivot pin from the knee link activating arm, use a puch from the other side of the brake to remove the roll pin securing the other end of the band, with the band out remove the screw securing the band to the knee link, install the knee link to a new brake band, re fit the roll pin in the band and re fit into the cover, insert the spring, this will have to be compressed to get it back in, re fit the spring cover, you need now to load the brake, fit the hand guard onto the cover, insert a conical puch through the hand guard and cover to enable you to pivot the hand guard back and load the brake, now fit the hand guard properly onto the cover and re fit the collors and screws.
Jul 26, 2012 | Husqvarna Garden
Brake on poulon chainsaw 18"
The brake on this machine is a knee link design, this is an over centre catch, if there is excessive dirt under the over centre mechanism it will not lock properly and so come on prematurley, you need to remove the brake from the machine, activate the brake to release most of the spring tention,remove the hand guard fixing screw and collers, remove the hand guard carefully remove the screws securing the spring cover, be aware there is a compression spring under here, inspect the internal components, clean out any accumulated dirt and debris, replace the cover and hand guard, load the brake by pulling the hand guard fully back, the other option is to just replace the complete brake assembly part no. 530054740
Aug 29, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do you pull the chain break apart on a poulan chainsaw 2150 and repair it.
The brake is a saftey item on the saw and should only be repaired by a quailified fitter, however if you should decide to do it yourslf that is down to you, the brake is a so called knee link brake, start by removing the brake from the saw, once removed activate the brake by pushing the hand guard forward untill you hear the brake come on, now remove the allen screw in the hand guard pivot ( do not remove the c clip in the side of the hand guard ), tap the pivot collers out from either side and remove the hand guard, remove the cross head screws securing the spring cover, BE AWARE THERE IS A COMPRESSION SPRING UNDER HERE, eye protection should be worn, with the cover off, pry out the spring, remover the small pin securing the knee link mechanism, using a small punch tap out the roll pin from the other side of the cover that secures the anchor end of the band, it should now come away, remove the cross head screw holding the band to the knee link mechanism. You can now replace the band, refit the the knee link to the new band, re fit to the machine, tap the roll pin back into the cover to secure the anchor end of the band, re fit the knee link pin, re fit the spring ( be carefull ) re fit the spring cover, place the hand guard back on the cover, use a suitable tapperd punch to insert through the hand guard and cover to hold it in place, now pull the hand guard fully back to load the brake, remove the punch and re fit the pivot collers and allen screw. Make sure the brake now functions properley.
Apr 09, 2011 | Poulan Garden
Bosch 1581 old style, blade is tightened with a screw driver. The screw to tighten the blade is lost. How to get part for an old style saw or have it repaired?
go to Boschtools.com and you can order online or find a Bosch center near you the part number is 2 603 400000 and it lists for 1.20, let me know if you need more assistance.
Dec 30, 2009 | Bosch Saws
Need a rocker switch for a Powermatic 63 A Artisan table saw part number 6285322
If you want to buy a new one, the Grizzly G1022 Table saw is an exact replica of the PM#63. A owners manual and parts list is available at their website. Grizzly.com
Jan 03, 2009 | Powermatic 1791227K Model 64 10" Artisan...
Remington 16 in. electric chain saw
Go to www.masterparts.net Remington chain saws are listed by bar length and model number. There is a parts list with each saw.
Oct 27, 2008 | Remington Electric Chain Saw
Saws Logo
48 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
