Question about Dryers
Where is heater reset button on my dryer - Dryers
    Genius:
  • 2,491 Answers
-There is not reset button. But there is thermal fuse.
Good Luck
mai
Posted on Nov 14, 2014
Electric dryer won't heat
Thermal overload cutout tripped or is defective and needs replaced. Look for a red reset button near the heater element on the thermal overload. If no reset button, replace the thermal overload cutout. The timer itself could be defective, which will prevent power going to the heater element.
Sep 14, 2015 | Roper Dryers
Where is the reset button for the heater
Most dryers do not have a reset button for the heater. No heat can mean several things. !st--heater may have burned out and needs replaced. 2nd-- some dryers have a thermal safety thermostat that if the dryer gets too hot it will trip off the heater. Usually it needs replaced when this happens and you need to see why it overheated like possibly a blocked vent pipe. 3rd-- no heat could be from a bad heat select switch, a bad operating thermostat, or a bad timer. You need to have some knowledge to trace the problem down and know how to use a multimeter for testing.
May 09, 2015 | Hotpoint Dryers
The dryer is not getting hot to dry the close, but there was something on the water heater pushing on a red button
unless I'n missing something the water heater has nothing to do with your dryer. If you have an electric dryer and the tumbler is turning then you have electricity to the dryer. If however the tumbler is not turning check the wall plugin. It probably is a CFI plug and may need to be reset.
Dec 21, 2014 | Maytag Clothes Dryer Almond Timer Knob...
How do I Reset the heat element in my LEW0050PQ electric dryer
you have a venting issue . blown heater fuse. it will do this till you address long ,blocked vent.
Sep 12, 2014 | Dryers
Is there a reset switch for the heating component of the Siemens WT46W560/08 dryer
This would be inside the back of the machine wired in line with heater element. Trace the wiring back from the heater element and you are most likely looking for a push button. PS! some machines have wiring diagram included in the back of the machine???
Aug 11, 2014 | Dryers
Where is the reset button?
Most Bosch dryers have a heater reset button behind the main rear panel. If this thermostat has tripped, there is a REASON, resetting it may make things work for a short time but your issue is bound to return. There are many other things to check on Bosch dryers to ensure proper air flow throughout the dryer and house venting. Pleazer Appliance...
May 01, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Heater won,t shutoff
we've had pretty much every problem you could have with this dryer.
Buy a different brand and send your fisher-junkel to the scrap yard.
Mar 14, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Not heating
It is probably a thermal fuse. Take off the back of the dryer and you will see it on the lint outlet tube. It is white and is 1/2 inches wide and 2 inches long. It has two leads coming out hooked to wires. To check it just pull one of the leads off, turn on the dryer and touch the wire you took off to the other one and the burner should come on. It costs $12 at a parts store.
Jan 31, 2008 | Roper RES7646KQ Electric Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
