Question about Radio Communications
No sound on my EBT950 bluetooth speaker
No sound via bluetooth or wired
Can I connect bose speaker to Sony blue ray via blue tooth
Is your Bose speaker a Bluetooth speaker ? Does your Sony blue ray player have Bluetooth ? You can connect the two only if Both are Bluetooth devices.
Feb 15, 2015 | Sony Televison & Video
Still need to know how to download music from cell phone to the Omnitech Bluetooth speakerphone everything else works except for music playing on my bluetooth
You do not download music from your cell phone to your Bluetooth speaker. You pair and connect your cell phone with the speaker via Bluetooth and when you listen to music or make phone calls on your phone the sound comes out through the speaker. Please read the instructions on how to connect the phone to the speaker.from the set up guide that came with the speaker.
Jan 03, 2015 | Cell Phones
How to pair ny mini bluetooth craig speaker to my
Turn on the bluetooth of your phone first: Go to settings>Wireless and Networks>Enable Bluetooth and disable discovery limit in bluetooth settings. After that make sure the bluetooth in your speaker is on and let your phone search the speaker and let it pair with it after that go into your phone's music player and look for its play options and if you see via bluetooth click it. Just let me know if you need further instructions or you could watch this video showing how he pairs his bluetooth speaker from his phone DBEST London Bluetooth Mini Speaker Review
Oct 16, 2014 | Cell Phones
Connected Auvio Bluetooth speaker to Samsung LN-S3241D TV via digital optical wire and digital-to-analog audio adapter; the sound plays great but the volume can not be adjusted with the speaker controls,...
Check your menu on the Samsung to switch audio out selector. You might have to use ANALOG outputs instead.
you could then eliminate digital to analog adapter.
Analog out uses the RCA PLUGS.
Jan 10, 2018 | AUVIO Bluetooth Portable Speaker
Making my craig bluetooth speaker discoverable
Through basic hacking, the code 0000 worked for me....
I wish it came to me sooner!
Craig Electronics CMA3532BT is the model number -
A tiny cylinder speaker - sounds pretty good for the tiny $$$ too.
MikeFilosa
Dec 02, 2012 | Craig Portable MP3 Speaker - CMA3016 White
Monster clarity does not work wired
Mine wouldn't either. Now I have paired it with the Bluetooth and it installed something (drivers?), and now it works. So, now how do I know if it is always connecting Bluetooth or wired? I connected the wire and it is still working, so now how do know if I really need the wire or not???
Oct 24, 2012 | Monster Clarity Hd Precision Micro...
Tomtom 520 no sound
Reset it. If that doesn't work, you need to have it repaired or replaced. If you have had it longer then 5 years, it is past its best by date. Having said that, you say it works fine to start with, so it can't be much wrong. If the sound comes via Bluetooth, delete the entry, reboot all devices and re-pair them.
Sep 16, 2017 | Tomtom GO 520 GPS Receiver
Unable to receive via bluetooth
Hi buddy,
Please check wheather ur memory is free or not then try to take the files from bluetooth.
Check both phone memory and memory card memory
Jul 29, 2009 | Nokia N90 Cellular Phone
Audio has a whining noise when connected through Bluetooth
I also own a Yamaha nx-b02 unit. Mine whines too, but only when connected via Bluetooth to my Vaio f series or my friend's htc.
They work perfectly on my older Toshiba laptop wich is equipped with Bluetooth 1.1. I suspect the problem only occurs with Bluetooth 2.x equipped devices. (might be wrong though)
Can anyone else add their experiences please?
Jun 02, 2009 | Yamaha NX-B02 Bluetooth Wireless Speaker
Sony erricson k800 cant recieve files via bluetooth although i can send via bluetooth.
Did you turn the bluetooth on and put the phone in discovery mode before attempting to receive something via bluetooth?
May 01, 2008 | Cell Phones
Radio Communications Logo
46 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
