Question about Water Heaters
<!-- from fixya rte -->Where is heater reset button - Water Heaters
  • Water Heaters Master
  • 5,245 Answers
Where can I find reset button and is there only one reset button
http://www.marathonheaters.com/useandcareguide.pdf Upper thermostat has only reset button.
Jul 31, 2014 | Marathon Lower Thermostat - Standard -...
Where is the reset button on reliance gas water heater
No reset button.
The gas control valve is the thermostat
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Intellivent gas control can be reset, and Honeywell can be reset under some circumstances.
Otherwise, bad thermostat means replace gas control valve
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 28, 2014 | Reliance & 50gal Electric Water Heater
Finally found the reset button on my Whirlpool hot water tank, but it will not budge when I push it. Why? Pilot will not light.
Reset button on gas water heater??
Usually there is not a reset button on gas water heater, which might explain why is doesn't move:
Do you mean the igniter button for lighting pilot?? The piezo igniter can go bad.
Copy following links for troubleshoot resources:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add comment with description of water heater, and more detail or call plumber.
Gene
h
Aug 23, 2013 | Water Heaters
Reset button on water heater keeps tripping
Need a new thermostat to keep the unit from tripping
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
Please help!! I can't find the reset button on my Rheem 81V52D C model water tank! I opened the top panel and didn't see a red reset button. Totally confused now. Please help?
if there is no reset button, you should be able to turn the breaker off for a few minutes. then turn it back on. if its an electric water heater! it should reset it. good-day !
Mar 26, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Called and was told to change lower thermostat but yet again I had to go push red reset button on top panel to get it back on to get hot water. what should I do now?
You have electric water heater.
You have top and bottom panel, so water heater is 240Volt.
No hot water because ECO reset button tripped.
Water heater works correctly when reset button is reset, so electric power and circuit breaker are good. Water heater wiring is probably good.
Problem is most likely bad thermostat.
I usually replace both upper and lower thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problems continue after replacing thermostats, then test and replace elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Aug 05, 2011 | RELIANCE ELECTRIC WATER HEATER
Circuit breaker in water heater will not reset.
If I understand correctly the red reset button or ECO located on upper thermostat will not reset.
Add a comment if problem is different.
Electric water heaters are fully repairable by homeowner.
If circuit breaker to water heater will not reset, then you need full troubleshoot using inexpensive multi-meter from Home Depot::
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If reset button will not reset, then two things can cause this problem.
1) Ground short between upper thermostat and upper element, including shorted upper element.
a) Look at wires to see visible signs of high heat and burning.
b) Test upper element for short.
http://waterheatertimer.org/How-to-test-water-heater-element.html
2) Upper thermostat is bad. Test upper thermostat, or just replace thermostat using generic upper thermostat from hardware store.
3) If problems persist:
Troubleshoot electric water heater using inexpensive multi-meter from Home Depot:
Upper thermostats are generic unless you have "energy-smart" water heater that has control box and reset button located on top of tank.
Nov 29, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a model 71-408 B which just stop heating
If I understand correctly, you have electric water heater.
Heater suddenly stopped heating.
Four things cause sudden loss of water heater.
1) Reset button located under the top cover is tripped > turn off power, remove cover, press reset button > if reset keeps tripping, go to the troubleshooting link shown below.
2) Electric power to heater is interrupted > check circuit breaker > test for voltage > look for loose wire on breaker
3) Upper element burned out > test and replace element
4) Upper thermostat bad > replace upper thermostat
Reset button is best suspect.
Here is a link for complete troubleshoot and homeowner repair of electric water heater:
Nov 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Top thermostat reset button kicks out
The top button is connected to the top heater element  which is likely shorting out. Drain the tank below the element that the thermostat is attached to. Remove and replace the element
Jan 24, 2009 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
48 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
