Question about Splendide 2000S Vented Washer/Dryer
Trum turns but will heat dyer. Is there an internal lint filter?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 211 Answers
Re-word your question please. No internal lint filter. If you mean it turns but does not heat then the safety switch burned out and no longer allows the heat strips to operate. This problem is generally caused by a clogged or nearly clogged exhaust hose. Replacing the switch can be tricky on some models but some can be done by removing the front panel others by removing panel and belt and drum. That's when you call an expert.
Posted on Sep 22, 2017
    Top Expert:
  • Splendide Master
  • 7,905 Answers
Bottom lower right remove panel drain if ok then lint filter inside top or lint in vent
Why frigidaire dyer model fex831cso not heating up?
Good Morning Friend,
I understand the dryer is not heating up on your Frigidaire laundry center, model# FEX831CS0. First, there are two house fuses that the dryer is plugged into. Make sure that both are good and the breaker has not been tripped. If one of the fuses is blown, this can cause your dryer to not heat. Secondly, make sure that the lint filter, lint trap area, ducting leading outside, and the outside exhaust duct are free of lint. This can cause your dryer to not dry, due to lack of ventilation. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEX831CS Top Load Stacked...
Dyer will not heat
Sounds like an open heating element issue. If you have two sensors for internal temps, the chances of both going bad at same time are remote.
Locate the element wiring and disconnect from circuit and do a simple continuity test. Chances are that it is burnt out or open.
Jan 28, 2014 | LG DLE7177 Dryer
Dryer is turning but not getting hot
what's the brand name of the dryer and send the model number,if it's gas does the ignitor glow orange but no flame,also if it's gas when you start it you should hear a click,if you don't most likely the dryer is clogged with lint or the vent line is blocked with lint and the high heat popped the thermal fuse,but let me know what you have
Jan 24, 2014 | Frigidaire 134844410 Fridgidaire Dryer...
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Dyer is not heating maytag dryer D8000
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
rtw
Sep 02, 2010 | Maytag Dryer Lint Filter Screen 33002970
Makes the clothes smell burnt or like a machine smell
your problem is most likely lint build up around the heating element to clean it the element and heat gard need to be removed. or it could be a slipping belt. last it could be your motor burning out though the first diagnosis is the most common to avoid this fault in the future it imperitive that the lint filter be cleaned of all lint after every single dry cycle as this is the most common reason for house fire regarding dyers as well
hope this helps
Jun 30, 2010 | Dryers
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Lint Filter
hi there,
i can understand your frustration. i have reviewed the information that i have from Bosch and they indicate that the lint filter indicator light should only come on as a reminder but should not shut off the dryer.
here is my recommendation and also a question:
the dryer is shutting off due to the fact that it's overheating. it's a safety precaution from the manufacturer and it's built in to prevent the lint collected in the lint filter, since it's highly flammable.
check the venting in the back or side, wherever it was installed.
the vent tube is often the cause for the dyer to stop functioning.
if that turns out to be okay, the dyer is equiped with a sensor on the heater. it is possible that it's opening due to the heat generated by the dryer that has nowhere to go.
does the display show any error messages?
can you tell me what they are?
thanks again
Sep 24, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Splendide 2000S Vented Washer/Dryer Logo
56 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
