Bizhub 501 how to check toner motor - Office Equipment & Supplies
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 21, 2009
HOW DO I CLEAR C3806 ERROR CODE ON BIZHUB 501? PLEASE FORWARD ALL DIAGNOSIS CODE
Fusing main temperature low sensing.
clean TH1-Thermistor.
Power ON machine by pressing Utility Button.
and hold for 15 to 20 seconds.
Touch TROUBLERESET once appear.
now restart machine from main Power which is under Toner Door
Dec 21, 2016 | Konica Minolta Bizhub 501 Copier
Code irror 2702
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Apr 26, 2016 | Konica Minolta BizHub 360 361 420 421 500...
I have one photocopier bizhub 501 and have error code 2801/03..Can you help me? thnx
Take the toner bottle out. Then you will need to remove several cover to gain access to the sensor way in the back of the where the toner bottle goes and clean that sensor. might even need replacing.
Aug 25, 2015 | Konica Minolta Bizhub 501 Copier
Find release for Bizhub 501 drawer
Sir, draw release is in the back power off the machine and stick a thin screw driver in the hole(Located behind the big draw) to release the large capacity draw!
Nov 03, 2014 | Konica Minolta Bizhub 501 Copier
C2801 konica minolta bizhub 501
TCR output abnormality. What is the status of your consumables (drum and developer)? You might need to replace the developer. Also, you should check if the toner bottle is turning; you should see it turning while the front cover door is open and the machine operates; if it is not turning, it is possible that the toner bottle was inserted wrong (by force).
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta bizhub Office Equipment &...
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Oct 05, 2013 | Konica Minolta Bizhub 501 Copier
Bizhub 501 error codes c3801
Maybe the power it's not correct.Try to reset hold utility key and power on hold the utility and on screen will be show the ikon trouble reset push it and will show ok power of and on again
Apr 29, 2013 | Konica Minolta Bizhub 501 Copier
How do I replace staples in bizhub 501
Open doors where toner is located.
Deep in the left cavity, you should find a brown unit in which the staple cartridge is located.
Carefully slide the unit towards you and when it reaches the edge, you can gently lift the blue handle and remove the empty cartridge.
Press each side and the spring will lift allowing you to remove the empty white cardboard staple holder. The arrows are to point away from the blue handle.
replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-0.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-1.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-3.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-6.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-10.jpg
Feb 20, 2013 | Konica Minolta Office Equipment & Supplies
Power up then goes immediately to code sc23-22 1050 bizhub
Toner pump motor (M28) abnormality. The rotation of the toner pump motor (M28) is checked. While M28 is rotating, an error detection signal (abnormal rotation) is detected for more than 1 second. At this time, error signals (blowout of a fuse and 24V cut off) are not detected.
Dec 14, 2010 | Konica Minolta Bizhub 222 Black and White...
57 people viewed this question
jasbo
jasbo
