Video for starting up - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
What is the problem you faces with this TV? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 14, 2014
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
Tip
How to Convert 2D Video to 3D Video Ever imagined that a normal 2D video can be...
How to Convert 2D Video to 3D Video <br /><br />Ever imagined that a normal 2D video can be magically turned into a 3D video which can be played by compatible software player on your computer or 3D TV? Using DVDFab 2D to 3D Converter, you can achieve this smoothly with success. 2D to 3D Converter is robust, quick, and easy to use. <br /><br />Required Tools: <a href="http://convert2dto3d.net/">2D to 3D Converter</a> <br /><br /><br /><b>2D Video to 3D Video&gt;Step 1: Run 2D to 3D Converter in Video Converter</b> <br /><br />2D to 3D Converter is embedded in Video Converter as the option of "2D to 3D", which is convenient for users to use both of the two products to finish this 2D to 3D conversion task. So we need to run Video Converter at first. Then choose a compatible mode from multiple supported ones ("to AVI", "to MKV", "to MP4", "to FLV") and import in the source video we want to convert. After the source video is loaded in, the "2D to 3D" option is ready to be selected with a check box in front of it, just check it. <br /><br /><img src="03e799ef87630e7db329a3d6b4ad32ac.png" /> <br /><br /><b>2D Video to 3D Video&gt;Step 2: Click Video Effect Settings button, and Edit button</b> <br /><br />Click Video Effect Settings button to customize the 3D format, video frame size, source aspect ratio, frame resolution, play region, etc. for the output 3D video. <br /><br /><img src="f54b135b729b8958eb35b3e0b857f22e.png" /> <br /><br /><img src="e870296a85008d2cadfe2edc5c7eaee8.png" /> <br /><br /><img src="3625486fded3ed529ef277b478691616.png" /> <br /><br />All right, now click Edit button on the main interface to set up a lot of video/audio parameters for the conversion. <br /><br /><img src="d06d9614161e664378c89f760d88b84c.png" /> <br /><br /><b>2D Video to 3D Video&gt;Step 3: Click Start button to <a href="http://convert2dto3d.net/">convert 2D to 3D</a></b> <br /><br />Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos <br />Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos
on Jul 05, 2011 | Computers & Internet
Tip
Convert video to Flash on mac with video to Flash converter for mac
Convert video to flash mac tool--helps you convert video to Flash video FLV and SWF with flash player Convert video to flash mac tool, Doremisoft video to flash converter mac, is an easy-to-use app for video to flash conversion on mac, converting almost all video to Flash video FLV and SWF, such as MP4, Quick Time video, MOV, 3GP, MPEG, MPG, M4V, WMV, AVI, MKV, RM, RMVB, HD video, etc. Additionally, the mac video to flash converter offers you to embed the converted video in an html webpage. Mac convert video to flash tool, video to flash converter for mac, offers you to edit your flash video with amazing editing features. For example: With mac video to flash converter, you can get any segment from the source video by using clipping feature. Merging feature can join several video files into a single one. You can crop flash video and add effect(Old film, gray, emboss) to flash video with cropping function of video to flash mac converter. Key functions of converting video to flash
  • Convert video to Flash
    Video to flash converter enables you to convert video to flash video FLV, SWF.
  • Generate HTML file
    When you convert video to flash on mac, the converter will automatically embed video in an HTML webpage so that you can add video to website without programming.
  • Crop video for flash video
    Get rid of black slides by moving frame lines to define the cropping area.
  • Applying effects
    Change video brightness, contrast and saturation and add effect to flash video like old film, emboss, gray.
  • Clip flash video
    Get your desired video by setting start and end time and you can clip as many times as you wish.
  • Slide flash video
    Sliding feature enables you to create flash video playlist.
  • Merge into one file
    Join Several video into a single file just by clicking “Merge” button.
  • Customize features
    Do audio and video settings, add flash players with skinning scrollable control bar, special effect, text/image and hyperlinks as watermark.
How do you convert video to flash on mac in two steps. Step one: Add video to convert to flash Free download and run convert video to flash software and click Add button to load video you want to convert for mac video to flash conversion. Step two: Start video to flash conversion Click Start button to start video to flash conversion. The process is fast and steady.
on Apr 08, 2010 | Computers & Internet
No video on start up
If you get no video ever, not even when the initial BIOS screen is supposed to appear, then you may have a failed video card or monitor. Your motherboard uses a PCIe-16 video card but has no on-board video. Check the motherboard manual for instructions on resetting the BIOS to factory defaults; perhaps the setting for the video card was corrupted.
If you get the BIOS splash screen and initial system start video, then it goes black, you have an OS problem. Try starting in safe mode to figure out what's going on.
Dec 30, 2010 | ASUS P7P55M Motherboard
My Video doesn't properly work.When I'm on line wirh CNN,to watch the news,the video starts but then it stops and starts and stops and starts,The video goes in spurts.
this is actually a connection issue and not a video issue this is a connection issue most likley as video playback probably works when your not watching videos online you just have to either let the video buffer up by pausing for a little while before you watch or see if you can lower the quality of the video so it can keep up with your connection speed
Sep 24, 2010 | HP Pavilion dv6000z Notebook
Tip
Wondershare Video Converter for Mac Guide
This is the step by step guide for Wondershare Video Converter for Mac.
Free download Wondershare Video Converter for Mac
Step 1: Add video files
Launch Video Converter for Mac, click 'Add Files' to browse your computer hard drive and select the videos you want to convert.
video-converter-for-mac-guide-1.jpg Step 2: Select the optimized output format for videos on Mac
After loading videos to the Mac Video Converter, choose the chapters or titles you want to rip, then click 'Format' to select the output format from the drop-down list.
video-converter-for-mac-guide-2.jpg Step 3: Start conversion
After all the settings, click the 'Start' button to start ripping DVD to destination format.
video-converter-for-mac-guide-3.jpgresource:mac video converter
on Mar 02, 2010 | Computers & Internet
Buffeting on video
First let the video buffer completely and then play it ..... lets say you want to view a video click on it and then pause the video the red line/bar will go across it finally when its done ... play it .... the video wont stop and start anymore
Apr 12, 2010 | Computers & Internet
FREQUENT START AND STOP DURING THE PLAY OF VIDEO
usually this happen when you have slow broadband connection and video is need more speed then your broadband connection speed if you have 512kbps internet speed you do not have to wait this long to watch video on you tube. check your internet connection speed for you tube video.
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 24, 2010 | YouTube Videos
Error when starting to export video to itunes
oh, why don't you try another soaftware?
Ultimate Video Download Studio helps you put any video format onto your iPad, iPod, iPod touch, iPod
video nano, iPhone, Zune, PSP, video capable MP3 players, video capable mobile
phones, and Pocket PC, etc.
Nov 02, 2009 | JVC Everio GZ-MG630 Hard Drive Camcorder
I cant see video from ipod
No in the ipod settings have u turned on the NSTF signal for the TV?
May 25, 2008 | Audiovox VM9512 Car DVD Player
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
