WHAT DOES H5 MEAN? - Heating & Cooling
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 54 Answers
I didn't see what model you have but from what I read H5 indicated IPM protection, yellow LED light blinks 4 times
Posted on Nov 26, 2014
What does error 85-01 mean on a sharp printer?
Hi do U mean H5-01 if so clear paper jam put it in Copy mode press on the keyboard. P * C * 14. CLICK EXECUTE and press Yes then press the COPY TAB IT should reset. Good luck
Nov 01, 2016 | Sharp Office Equipment & Supplies
What is mean by call sevices code H5-01 in sharp mx printer
H5-01 means repeated paper jams on the Sharp photocopiers.
Once the paper jam is cleared properly, you need to clear the error condition.
Put it in 'Copy' mode
Press on the keypad:
P * C * 14
Click execute and press 'Yes'
Then press the 'Copy' tab.
This will reset the menu and jam condition.
May 21, 2015 | Sharp Office Equipment & Supplies
What does this mean Hayward pool heater h150FDN gives us an hs or h5 error?
HS = High Limit Sensor
Heaters Maximum Water Temperature has been Exceeded.
A few reasons this occurs...
  • Low water flow thru heater, check :
    • Dirty Filter
    • Opened By Pass Valves
    • Plugged pump impeller
    • Dirty/Full baskets at skimmer or pump
    • Anything that may reduce water flow
  • Sensor could actually be doing its job, in a different aspect, Thermostat failure, and water is overheating in spa or pool?
But anyway, your heaters fault code you asked about is: hs, not h5
May 17, 2014 | Hayward Pool & Spa
H5-01 keeps popping up when I try to copy, states contact repair person, whats it mean
it means u have a problem with your fuser unit causing the machine to jam.... h5 01 means it has jammed 5 times in a row for u . likely scenario is the time it jammed for U DID NOT FIND THE ACCORDIANED UP PIECE OF PAPER IN THE FUSING UNIT....the machine will reset from a misfeed condition even though this sheet is not found & removed ...so u made a 2ND atempt then 3rd then a4th & on the 5th attempt u got the h5 01 .NOW i am willing to bet u have 5 sheets of paper in that fusing unit that u need to locate & remove. THEN the h5 01 code will need to be reset by executing a simulation 14 ,, u need to indicate the model # before that can be done
Jan 25, 2013 | Office Equipment & Supplies
ERROR H5:01
HI there ERROR H5:01 mean mechanical problem. This error code says call service person for copier.
Jan 25, 2011 | OKI B8300 Laser Printer
We are getting a code H5-01 what does this
H5-01 means there were five consecutive jams at the fuser section. Open the left jam door and look up in the fuser (heat) section and at the top of it You should find sheets crunched into an accordian After clearing all the paper from this area close up the copier Turn it on and press the copy mode key Then the following keys in order one after the other Program..*..C..* The display will change to service mode input 14 then the copy start key enter 1 for yes then the copy start key if the copier does not restart itself then hit the CA key the copier sholr reset and start with out the code
Feb 17, 2010 | Sharp AR-M355U Copier
How do I turn my flash on--I have a sony cybershot DSC HF camera! Thanks!
Do you mean a DSC H5? If so, at the top of the control button there should be a symbol that looks like a lightning bolt with a arrow on the bottom. Push that to go through the various flash settings.
You can get the manual here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-H5&region_id=1
The 'Read This First' file is a quick guide to using your camera and is also available on that page. And, if you didn't mean H5, then you can change the model.
Aug 01, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
CODE H5-01
how to clear the problem, it shows:
call for service. code: H5-01
Apr 22, 2008 | Sharp Office Equipment & Supplies
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
