<!-- from fixya rte -->Can I have a you view box free - Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
I got my YouView box free when I signed up for BT Infinity (upgraded from standard broadband), and TV Essentials (replacing my BT Vision which had ceased). The link below will take you to a BT page which may help you,
TV Packages And Deals Online BT
although I found it difficult to sort out what I would get on line and in the end rang them
Cheers
Posted on Nov 13, 2014
How do i access Freeview without Sky
http://www.google.co.uk/search?sourceid=chrome&ie=UTF-8&q=Freeview+box#q=Freeview+box&hl=en&sa=X&biw=1680&bih=925&tbs=shop:1,p_ord:p&prmd=ivnsr&ei=idt7TYzqB4qFhQfhmqX9Bg&ved=0CAoQuw0oAQ&fp=9de9b54e9db2914f
Unless your flat panel has built in free-view in which case we would need a model to identify how to access you'll need a free-view box which are relatively cheap from most shops
Mar 12, 2011 | Televison & Video
How do i get my funai vcr to record from my freeview box. I can only record through my analogue channels. I have a funai vcr either 31B-750 or 31B-754 (PDC) and the freeview is an Astratc TopD2
hi, how is the free view running through the video?
Option 1(this is the most complicated way if you are using scart lead or the three color leads then skip to option 2)
if you using the normal arial socket ie arial from roof goes into free view then from free view into vid then vid into tell then what you need to do is make sure on the free view that you have a menu screen on the screen either tv guide or something that will stay on their.
Now put the video on a channel you dont use say 6 then you need to use the video remote and then enter the setup mode and then start the scanning process to look for the signal keep going until you get the menu screen that you opened on the free view then store this as channel 6 on the video.
Now when you want to record from the free view you put the video on channel 6 and put the free view on the channel you want to record.
Option 2:
If you free view box is using scart leads and has two scart lead outputs on the back, ie one for the telly and the other for the video, if you have it like this then plug telly scart into telly and video scart into video.
Now in the back of the video you should have scart lead coming from the free view, and maybe one coming from the video into the telly
If this is the case then all you need to do to record off free view is switch the video on the when you choose what channel you want to record instead of choosing 1 to 5 for normal channels you need to select av scroll down the channels past zero if you have not got av button once av is selected you should then see the free view channels try by pressing guide on the free view and put the video on av this should then let you see the free view via video if not dont worry press record for 5 min then rewind and press play it should now play back the free view you was just watching.
Option 3 now if you have it set up any other way just let me know how then i can assist you further ok.
If you have any problems following my instructions then just post me a message back and ill be glad to assist you further ok.
Many thanks for using fixya.com
Nov 18, 2009 | Electrical Supplies
How to install digital TV via Free View Box
Put ur tv in channel 3,take the cable came with the converter box put it in tv antna hole in the tv ,the other to the converter box said tv.Take antena,portable or roof antena put it in the converter box said antena hole. Go to menu resacan channels u done.
Nov 15, 2009 | Televison & Video
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
I have lost a number of channels on my free view digi box ie ITV, C4, C5 etc. How can they be restored. I have tried retuning the box but it does not work.
This is a technical problem with your local service provider. Doubtful that it is your box unless the free view portion has expired. Otherwise check with your provider. If it is not a technical problem with them they will send someone out to investigate.
Sep 11, 2008 | Televison & Video
Dvdrecorder and convertor box
If the clarification request is correct. The only thing i can suggest is. Plug aerial into converter box. plug converter box into TV using either scart or coaxial cable. then connect converter box to dvd recorder using scart or coaxial cable depending on what you used to plug converter box into TV with. Then plug dvd recorder into TV. I don't know if you have to set-up the converter box to start receiving i'm not sure. But try this anyway.
You'd probably have been better off getting a free-view box and your dvd recorder. Because as long as you've got a free-view box you'll always get digital. Hope this helps
Jul 29, 2008 | Televison & Video
Star view box will only display free view channels, what do I do?
HAVE YOU SORTED YOUR BOX OUT? IF NOT LET ME NO AND ILL TALK YOU THROUGH IT
Jun 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
